Juma, you SHOULD feel MANY wires.
Crew Cab XE will have wires for power door locks, power windows, and speakers.
Even the KC XE has wires for the speakers.
Crew cabs come with the PDL and PW features standard.
RedFish, The panel is pretty easy if you have a plastic wedge tool or something to get under the edge without cutting up your fingers, and a small hook tool to pull the retaining ring from beneath the window roll-up handle.
The screws are:
1) Yank up on the arm rest and theres one
2) Remove the vertical trim piece that's in the handle coming from the armrest, that's another.
3) Beneath the small plastic cover under the door handle, another
Did I forget one? I thought there were 4... I'll go look later.
Like most door panels, once the screws are out, you start to yank on the panel starting at the bottom working your way up. The plastic trim clips will just pop off. Then you lift the panel out of the window sill. Detach any wiring harnesses and cables/rods and you're free.
KC XE Smoke
