Old 07-17-2004, 05:22 AM   #1 (permalink)
VShortt's Avatar
Tire Pressure
I am taking my truck in today to have the tires turned around so that the raised white letters are to the inside. I was wondering if anyone could tell me the pressure that is ideal for my situation. My driving is almost never offroad. I am usually only on highways and city streets. My truck is a 4x2 LE with the stock Goodyear 18's. Any help would be great.
New List of Mods Coming soon
Old 07-17-2004, 07:08 AM   #2 (permalink)
I was running 36 (cold with a hand gage) with the OR package tires. When I rotated them, I noticed they were beginning to cup, so I raised pressure to 40. By "cup" I mean that the tread in the central portion of the tire appears to wear more than the inner and outer edge portions. I don't know if the higher pressure will help or not. You might want to keep an eye on your tires for the cupping issue. In some cases this can apparently be a function of the tires, and in other cases be caused by the shocks.
Old 07-17-2004, 07:31 AM   #3 (permalink)
I run 42 on my KC XE 2WD and get 19-20.5 mpg. once even 22. juma
Old 07-17-2004, 08:53 AM   #4 (permalink)
goathead's Avatar
go by the door sticker. i was wondering what pressure to run, and everybody has a different opinion on that. so i asked a guy i know who runs a tire shop. he said the door sticker is what to run b/c they take into count the vehicle size/weight. it says 35 psi cold so thats what i run. with no problems. btw, cupping is the opposite, wear on the outside first, typically from too low of pressure. too high and you will wear out the center first. flame on................
steve
steve
Old 07-17-2004, 01:12 PM   #5 (permalink)
titanwild's Avatar
Went from 47psi as delivered (could feel every tar strip and pebble) to recommended 35 psi. That felt a little mushy to me on some moderate cornering that I do every day, so went to 38psi all around and it feels just right. No noticeable wear on either center or shoulders of tread. This is all very subjective, so just give it a try.
TitanWild
DeepWater 4x2 KingCab SE,
Big Tow, RF Pop, and Bed Packages, 29Mar04 MDate, Custom Flo-Pro Crossflow Dual Exhaust,
JetTech Traction bars, K&N drop In, OEM Fogs, XD5 9005/9006 Xenon bulbs, Viper 350 Alarm.
titanwild is offline   Reply With Quote
Old 07-17-2004, 01:29 PM   #6 (permalink)
CaliforniaTitan's Avatar
I am running 35 fronts and 38 rears for the best ride and milage at this point....Ours is a 86 mile commute when we take her each day (80%fwy 20% traffic)
Chris
Old 07-17-2004, 02:46 PM   #7 (permalink)
ensclark's Avatar
Send a message via AIM to ensclark
I run them on the high side, 37- 40psi. Drop them down when off road. Oh and cupping is the uneven ware of the side of the tire. Mostly seen on the inside of the tire, normally caused by tire skip when in a turn. Not sliding from the front pushing but the inside tire in a turn bouncing a little. If you run your hand over it, it feels like waves. My F150 and Ranger, both 4x4, had it bad. One other reason I have the titan and hope it doesn’t get it bad. In my ranger I had to stiffen up the front to keep it down. If your tire has worn evenly only on the inside or the out side then you might want to get your alignment checked.
White LE CC 4X4, OffRoad, Big Tow,Nav, DVD, back up sonar, sun roof, bug and window deflectors, Westin Bull Bar, K&N aircharger, A.R.E. bed cover, Centerline Stingray III's 17X8s, Utility Bed Package, W/ sliding bed extender and divider, Side air bags, all leather, Captain chairs. http://www.nitrousenterprises.com/ 3 inch Lift Kit. BFG 315/70-17 A/T
ensclark is offline   Reply With Quote
