Titan A/C Blower Fan & VBC install...FIX! - Nissan Titan Forum
post #1 of 32 (permalink) Old 08-24-2011, 02:44 AM Thread Starter
Garage
iTrader Score: 5 reviews
Send a message via AIM to JauntyBishop
Well... my almost 3 year old titan with 72000miles, a/c blower fan and 5-fin variable blower control module (VBC) went out.
I have the NON dual climate control a/c. I have the standard A/C just so you all know.
So here are some pictures of what the factory Nissan Titan blower fan looks like after 3 years of use, bearing failure and....RUST! I even found a pine needle and some leaves in my fan...weird...
Also, on a positive note I have even posted a picture of which bolts and connectors you need to disconnect/unscrew to replace your blower fan and VBC if yours ever goes out.
This whole replacement start to finish was about 30mins... very simple.
Pics of all the components of rusted, haggard, beat up, Siemens/Nissan AC blower fan assembly.
Well enough on the destruction of the old blower motor, which it took me longer to take apart this thing than it did to replace a new blower motor and VBC.
Here is the HOW-TO for you fellow Do-it-yourself'ers.
Tools Needed.
Blower Fan Unit and VBC are located under Glove box on passenger Side.
-Ratchet 1/4in drive, 3in extension.
-7mm socket
-5.5mm socket
-Flat blade screwdriver to remove plugs
-Flashlight
-Cigarettes (well....just saying)
If you guys/girls have any questions about the install. Let me know.
I will say this though, I got these parts at my local Nissan Dealership and the VBC and Blower Fan unit set me back $380.
So if your A/C fan ever starts staying on high or low speeds no matter what the dial/knob is set too... or like my situation the fan stayed on high even if the knob was turned off. Then it is 99% most likely the Variable Control Module(VBC).
If you hear chirping/grinding/squealing coming from under your glove box, I hate to say it but its time to replace your Blower fan unit.
If you wanna buy parts, go to MightyTitans, PM member 'BigBruno' (David Riddle) he is a parts dept manager for Douglas Nissan. He will hook you up. I have ordered from him before. Very Reputable and quick shipping and cost a hella less than local dealers.
Also, Remember when ordering parts to supply the tech with the last 8 digits of your VIN so you get the right part #s.
Happy Motoring!
Cory
2008.5 Crew Cab SE FFV 2wd.
Bolt ons... 377rwhp/432rwtq (Dynocom 5000)
MOD LIST with Current Projects (Custom Headers and Cylinder head build) Link Below.
http://www.titantalk.com/forums/tita...pic-heavy.html
JauntyBishop is offline
The Following 5 Users Say Thank You to JauntyBishop For This Useful Post:
ColoradoTitanPro4X (11-15-2014), gweasel77 (08-30-2012), kdo2milger (03-04-2013), nrhfamily (08-29-2012), tcoche (08-29-2012)
Advertisement
post #2 of 32 (permalink) Old 08-24-2011, 06:55 AM
gweasel77's Avatar
Garage
iTrader Score: 6 reviews
Re: Titan A/C Blower Fan & VBC install...FIX!
Nice writeup! Thanks, might come in handy one day?
I like the part about the cigrits! Chooch it buddy! LOL
2005 NISSAN TITAN SE KC
IRCVK56/TEAMVK56 Crew Chief
performance:
UP/REV (RB's TUNED)
4" Airaid MXP CAI w/ GW77 4" Ram-Air Mod / TB Bypass Mod / FT90 Kit / LS7 TB / '08 IM / CSF 2 Core Rad w/ Fumoto QuikValve / Nismo 170*F T-Stat / TruCool SR4588 / Nismo LT Header's / BerkTech B-Pipes w/ MF Hi-Flows / FlowMaster Y-Pipe / BORLA XR1 / Relentless RPM Gen2 Catch Can / Detriot TruTrac LSD / Grounding Kit / Burnout Mod / IAT "Reaper Mod" / LP Mod / MT ET Street P295/45R/17 DR's / Mobil1 Full Syn 5W30
exterior/suspension:
Ruff Racing R286 22"x9.5" Chrome w/ 305/45/22 Toyo Proxes ST2's / Slotted "Cryo" Frozen Rotors / Hawk LTS Pads / Gatorback Poly-V Serp Belt / Stillen Diff. Cover / PRG Street Bars / Helwig RSB / Bilstein 5100's & HD's / SpringTech Drop Shackles / PRG camber bolts / SolarGard Tint / CF Mirrors & Door Handles / Custom CF wrapped Interior / Morimoto XB 6K HID's / Full LED Retrofit (Interior & Exterior) / LED Cube Fogs / Diode Dynamics Tails, TRS Switchback (Front Blinkers) & Samsung Reverse...etc.
NEW PB 2014: 1/4- 13.55 @ 98.5MPH
Next Mods: CAJUN 2.5"-3" Y-Pipe Kit / MGT90
gweasel77 is offline
post #3 of 32 (permalink) Old 08-24-2011, 07:01 AM
Banned
iTrader Score: 0 reviews
Mine will be coming out soon.
The clicking bearings are driving me nuts! LOL
unknownTitan is offline
post #4 of 32 (permalink) Old 08-24-2011, 07:39 AM
beason's Avatar
iTrader Score: 10 reviews
Send a message via AIM to beason Send a message via MSN to beason Send a message via Yahoo to beason
check to make sure you have the filters in place. The last time i changed mine, i knocked a couple of leaves down into the fan, and it started making a heck of a racket. if you had leaves and pine needles in there, you may be missing the filters.
Adding them may also extend the life of the new fan!
Titan mod list here
WhinyWhore™
beason is offline
The Following User Says Thank You to beason For This Useful Post:
post #5 of 32 (permalink) Old 08-24-2011, 08:32 AM
Banned
I pulled mine just to make sure there was nothing in it, as I have found before. It's the bearings going out.
I can get a used one for about $50 from an 09', which is better then the $200 for an OEM from the dealer.
post #6 of 32 (permalink) Old 08-25-2011, 01:29 AM Thread Starter
Garage
The filter you guys are referring too is the in cabin filter right? I was wondering about changing that or any other interior filters for the A/C components.
Could you guys explain how to remove the glove box or the steps on how to remove/change these filters you were referring too?
Cory
post #7 of 32 (permalink) Old 08-25-2011, 01:30 AM Thread Starter
Garage
Cory
post #8 of 32 (permalink) Old 10-18-2011, 11:57 AM
flipcrab85's Avatar
iTrader Score: 1 reviews
Anyone have the part number for the vbc for an 06?
flipcrab85 is offline
post #9 of 32 (permalink) Old 10-19-2011, 08:28 AM Thread Starter
Garage
It will depend on if you have dual climate control or just standard. Make sure they use your VIN to pull up the correct VBC and Blower fan. You don't want to get the wrong finned VBC since it is a resistor.
Or you can just pull the VBC out, only two bolts holding it in and cross check the serial/product number on it and Nissan should be able to get the exact one.
Cory
post #10 of 32 (permalink) Old 10-19-2011, 08:49 AM
beason's Avatar
http://www.titantalk.com/forums/tita...r-filters.html
Titan mod list here
WhinyWhore™
beason is offline
post #11 of 32 (permalink) Old 08-29-2012, 05:49 AM
Lower your glove box door and look up to the right and you will see the screw for the door that covers the filters. I ended up pulling the fan to get the leaves pine needles acorns that dropped down and used a small shop vac to clean aiirways also lifted visor piece under wipers and sucked it clean, Hope this helps
a421tigger is offline
The Following User Says Thank You to a421tigger For This Useful Post:
JauntyBishop (08-30-2012)
post #12 of 32 (permalink) Old 08-29-2012, 02:34 PM
tcoche's Avatar
Very nice writeup...thanks bro.
I have a question, is there any possibility to change my blower to a better one?? I have an 04 and my max blower setting on the dial is 4. I want it to blow stronger. I have seen newer model dials that are not numbered, they have dashes or whatever you wanna call them. It looks like these would blow stronger, or am I wrong and there is nothing I can do??
Thanks!
Sent from my Autoguide iPhone app
2004 KC 4x4 Offroad 3.36 gears
Current Mods-
Suspension: RC 6'' lift, PRG UCA's (custom powder coated, maroon), PRG offroad traction bars, PRG driveshaft spacer, bilstein 5100's (lowest setting)
Performance: Uprev Tuner, 4'' Airaid MXP CAI, NismO low temp (62*C) thermostat, saikou michi oil catch can, goodyear gatorback belt, PML diff cover (color matched), rear axle vent mod, gutted b-pipe cats, flowmaster Y pipe, flowmaster 40 series muffler (dumped before rear axle)
Exterior: 35x12.5x17'' maxxis bighorns, royalty core grille, 1.75'' Bora wheel adapters, headlight mod, westin bullbar, KC driving slimlites, smoked clearance lights, bedlined wheels, mirror caps, rear bumper, front bumper and westin step bars, color matched locking fiberglass tonneau cover, tinted tail lights and 3rd brake light, 20% tint and limo tint eyebrow
Interior: WeatherTech digitalfit floorliners, custom radio bezel kit
tcoche is offline
post #13 of 32 (permalink) Old 08-30-2012, 12:15 AM Thread Starter
Garage
I honestly can't say, I know you have to use the correct VBC for the Blower Fan, And I'm not 100% sure if the Blower motor/fan even changed over the years, you would have to cross reference your year model to say an 08 or newer
Cory
post #14 of 32 (permalink) Old 08-30-2012, 12:44 AM
reds_titan's Avatar
hmm... i wonder if i can turn and rewind that stator to make it higher performance like i do on my RC cars...
2006 "Yota Killer" SE 4x4
180,000 Miles and Counting
Duel 2.5" to 3" si/so generic Magnaflow, S&B Ram Air Intake
CSF Rad, Tru-Cool 4590, 5100's w/08 springs, Modified Coil Bucket, CVT Rock Sliders, 2" PRG Spacer, RC UCAs
35x12.5R17 BFG KM2's on Machined XD Addicts, Drilled/Slotted Discs with Hawk HPS Pads, 2" Wheel Spacers,
Front Glassworks Fenders, Custom Speaker Box (built by me) with (2) 8" Fosgates, 800 Watt AMP,
Sony In Dash DVD Player, LEGIT ACCESSORIES Full Interior, Super Reverses, 20" Duel Row and Cubes
Want List
Headers, Cajun B-Pipes, UpRev, LEGIT ACCESSORIES 50" Curved LED Bar
reds_titan is offline
post #15 of 32 (permalink) Old 08-31-2012, 04:02 AM Thread Starter
Garage
Give it a shot and post results lol. Gonna turn the dayum a/c blower motor into a turbo lol... gonna have to direct my a/c ducts to my intake now lol.
Cory
The Following User Says Thank You to JauntyBishop For This Useful Post:
reds_titan (08-31-2012)
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
A/c blower out on Titan fatboylacombe Titan Problems & Dealer Service 51 07-07-2015 10:09 AM
AC Blower ncbandit75 Titan General Discussion 7 08-17-2011 10:04 AM
A/C Blower DIY jsnbrd Titan Problems & Dealer Service 14 09-08-2010 05:24 AM
2005 Titan Blower Resistor Location wpwilber Titan General Discussion 5 08-27-2010 07:41 PM
'08 Titan LE A/C Fan Blower Problem gedunk Titan Problems & Dealer Service 2 10-14-2007 08:44 PM
You may post new threads
You may post replies
