Speedometer should show faster,I think??
I think the speedometer will show you are going faster than actual speed.This tire has a(calculated) 171 mm sidewall,the 265/70 18 has a 185 mm sidewall.The 285/60 speedometer will measure turns per minute,and you will travel a shorter distance with each wheel-or driveshaft- turn.I could have this backwards.Charlie
