Old 07-22-2004, 11:41 PM   #1 (permalink)
BigPete's Avatar
Banks Tubing and stock muffler...
As you can see by my other posts I am having a rough time after installing the Banks exhaust; noise, engine sputtering. Does anyone know of a compromise? Is there a way to put on a stock muffler but keep the Banks exhaust tubing?
King Cab LE 4x4
Overhead Rack
K&N Air Charger
Banks Exhaust
Lund Bug Sheild
Eclipse AVN2454
Rockford Fosgate Punch series 301
Rockford Fosgate Punch series 401
Infinity Kaapa series 50.5
Infinity Kaapa series 63.5
Rockford Fosgate dual voice coil 8" sub
BigPete is offline   Reply With Quote
Old 07-23-2004, 12:00 AM   #2 (permalink)
Big Platinum's Avatar
I'd say keep the banks muffler and the single 3" piping but switch out everything before the y pipe. The dual 3" into single 3" isn't too good for power across the band and will make louder. IMO
I have the JBA setup and love it, dual 2-1/2 (maybe 2-1/4) into single 3", good compromise between HP and Torque. Also, if it's too loud, consider swapping out the 5" tip for a 3".
CC LE Smoke
JBA Cat Back Exhaust
K&N CAI
10" Fosgate He2
-Emerson
Big Platinum is offline   Reply With Quote
Old 07-23-2004, 03:04 AM   #3 (permalink)
for noise, see my post " who got drone" in the performance section. this techinique will cut noise. How long has it been on? it will probably need 300 miles to settle down and work right/run smoothly. juma
Old 07-23-2004, 04:18 PM   #4 (permalink)
BigPete's Avatar
It’s only been on for about 70 miles now. Engine is still sputtering when given very little throttle from a dead stop. Maybe it’s the ECU getting used to the K&N CAI and the Banks.
I did remove the 5" "bugle horn" looking tail pipe tip. That made a difference in the sound. We will see over time (if I can stand it) if it gets quieter.
King Cab LE 4x4
Overhead Rack
K&N Air Charger
Banks Exhaust
Lund Bug Sheild
Eclipse AVN2454
Old 07-24-2004, 05:28 AM   #5 (permalink)
lcbrownz's Avatar
Mine started sputtering at idle about about 200 miles after I installed my K&N. I took it to the dealership and they reset the ECU and everything works fine now.
lcbrownz is offline   Reply With Quote
