Factory running boards chipping?
I posted this is Problems/Service but I didnt get the response I was looking for. This is something that I think anyone with factory running boards should check out.
I found the paint chipping off my running boards. If you look at the top of them (not the bottom where youd expect it) and see little white "flakes" feel them. They're most likely chips.
Mine is concetrated on the passenger side board on the top near the rear. The drivers side only has a couple chips, but I'm sure is getting worse.
Mine only has 4000 miles, and I know there are older ones out there, so next time you're out there, take a look to see if this is happening on your running boards as well.
