Originally Posted by Slurppie
So do you cover anything up when spraying Simple Green on and hosing it down?
No, just spray the simple green on, let it sit for a couple of minutes then hose it off. This is probably the 6th time I've done this engine. I did it fairly often this past winter and spring while I had it in Maine to get all the dirt off it and to keep it as salt free as I could.
Blast away.......
Just as an added note, it's good practice to use some sort of shine on your engine after you clean it. The polymers and silicones used today help keep your wires and hoses from becoming brittle. Shine away....
