how do I check transmission fluid level - Nissan Titan Forum
Old 08-01-2004, 02:27 PM   #1 (permalink)
trowelsworth's Avatar
iTrader Score: 0 reviews
The owners manual does'nt show where proper fluid level should be on dipstick, nor does it say to check with engine running . Can anyone help me out, please.
trowelsworth is offline   Reply With Quote
Advertisement
Old 08-01-2004, 02:48 PM   #2 (permalink)
iTrader Score: 1 reviews
the dipstick is not marked, no holes, nothing??
to check you get it hot, come to stop on level ground, go through each gear and reverse holding for about 10 seconds in each, then put in park and go check the dipstick. I've never checked it but that's basically what is says in the service manual. juma
Old 08-01-2004, 03:13 PM   #3 (permalink)
Nissan Junkie's Avatar
some of the newer built titans, (like the one I was looking at) have a sealed tranny, that doesn't need to be serviced for 100k... or that is what the sales man told me... but there was just a cap where the dipstick should have been...
A truck should ride like a sports car....
...that has handling issues.
Nissan Junkie is offline   Reply With Quote
Old 08-01-2004, 03:49 PM   #4 (permalink)
IMADOGMAN's Avatar
From the service manual:
AT-10
Checking A/T Fluid ECS007S7
1. Warm up engine.
2. Check for fluid leakage.
3. Remove the tightening bolt for ATF level gauge.
4. Before driving, fluid level can be checked at fluid temperatures of 30° to 50°C (86° to 122°F) using
“COLD” range on ATF level gauge as follows.
a. Park vehicle on level surface and set parking brake.
b. Start engine and move selector lever through each gear position. Leave selector lever in “P” position.
c. Check fluid level with engine idling.
d. Remove ATF level gauge and wipe clean with lint-free paper.
CAUTION:
When wiping away the fluid level gauge, always use lint-free paper, not a cloth one.
e. Re-insert ATF level gauge into charging pipe as far as it will go.
CAUTION:
To check fluid level, insert the ATF level gauge until the cap contacts the end of the charging pipe,
with the gauge reversed from the normal attachment conditions.
f. Remove ATF level gauge and note reading. If reading is at low side of range, add fluid to the charging
pipe.
CAUTION:
Do not overfill.
5. Increase ATF oil temperature to 80°C (176°F) once.
6. Make the fluid temperature approximately 65°C (149°F).
NOTE:
Fluid level will be greatly affected by temperature as shown in figure. (Figure not shown here )
Therefore, be certain to perform
operation while checking data with CONSULT-II.
a. Connect CONSULT-II to data link connector.
b. Select “MAIN SIGNALS” in “DATA MONITOR” mode for “A/T” with CONSULT-II.
c. Read out the value of “ATF TEMP 1”.
7. Re-check fluid level at fluid temperatures of approximately 65°C (149°F) using “HOT” range on A/T fluid
level gauge.
CAUTION:
_ When wiping away the fluid level gauge, always use lint-free paper, not a cloth one.
_ To check fluid level, insert the ATF level gauge until the
cap contacts the end of the charging pipe, with the gauge
reversed from the normal attachment conditions as
shown.
8. Check fluid condition.
_ If fluid is very dark or smells burned, refer to check operation
of A/T. Flush cooling system after repair of A/T.
_ If ATF contains frictional material (clutches, bands, etc.),
replace radiator and flush cooler line using cleaning solvent
and compressed air after repair of A/T. Refer to CO-9, "RADIATOR"
9. Install the removed ATF level gauge into the fluid charging pipe.
Level gauge bolt: : 5.1 N·m (0.52 kg-m, 45 in-lb)
JBA Longtube Headers
Cajun Catted B-pipes
JBA Catback exhaust with Vibrant UltraQuiet Resonator
Tuning by UpRev (Seymore4)
IMADOGMAN
2004 NISSAN TITAN KC SE
4x4 Offroad (E-locker)
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
Old 08-01-2004, 04:36 PM   #5 (permalink)
Thanks IMADOGMAN, Your The Man! Pulled my brushgaurd off this morning to do an oil change. There was tranny fluid on the tranny cooler line that goes in to the top of the cooler, also the foam rubber in said area was soaked! Cleaned with simple green, drove for an hour came back and discovered source of leak. The rubber hose that makes the 90 at top of line is leaking. I'm going to reclean and replace hose crimp with stainless hose clamp immedietly. Off to dealer to top off fluid tommorrow morning. Can't thank you enough DOGMAN!!!!!!!
Old 08-01-2004, 05:39 PM   #6 (permalink)
IMADOGMAN's Avatar
YW
Glad you caught the leak before it got worse...
IMADOGMAN
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
Old 08-02-2004, 02:18 AM   #7 (permalink)
AT-10
1. Warm up engine.
CAUTION:
CAUTION:
pipe.
CAUTION:
Do not overfill.
NOTE:
level gauge.
CAUTION:
shown.
Do a search on how to check the fluid. Austin posted it dated 05-07-2004 who downlaoded the svc. manual. The manual says to reverse the gauge from it's normal inserted position to check the fluid.
1Titan is offline   Reply With Quote
Old 08-02-2004, 02:21 AM   #8 (permalink)
IMADOGMAN- Sorry I did not see when I first seen your reply step e. I thought it was accidentally omitted but the I noticed it right when I clicked submit reply.
Old 12-19-2005, 09:25 AM   #9 (permalink)
Triple S's Avatar
Re: how do I check transmission fluid level
4. Before driving, fluid level can be checked at fluid temperatures of 30° to 50°C (86° to 122°F) using “COLD” range on ATF level gauge as follows.
CAUTION:
To check fluid level, insert the ATF level gauge until the cap contacts the end of the charging pipe, with the gauge reversed from the normal attachment conditions.
Great post!
I do have a few other questions...
4- If I have the truck up to operating temp is there a "HOT" range or am I using the "COLD" range?
b- how long should I be in each gear or a I just going from P down to 1 and then putting it back in P?
e and CAUTION- am I contacting the cap to the pipe or am I putting it in as far as it goes, these are not the same in my mind?
and what on earth does this mean, reversed how? reversed from the normal attachment conditions
I'm sick and tired of all the problems...
Triple S is offline   Reply With Quote
Old 12-19-2005, 10:22 AM   #10 (permalink)
Clint's Avatar
I was told it was bolted and not user serviceable like the old days. They said the fluid gets checked with a guage by the dealer to a specific temperature and topped off as needed. The fluid is NissanMatic J and can't be bought at the parts store.
My thinking is if they don't put it in the manual with a time to check it then they must be willing to eat a trans.
Clint
You have two choices in life:
Old 12-20-2005, 01:37 PM   #11 (permalink)
Triple S's Avatar
Originally Posted by Quad T
Great post!
Can anyone help me out?
I still have these questions.
And as far as not checking because the tube is bolted closed... I have experienced several leaks on this truck to date as evidenced by the oil slick I used to call my driveway. I honestly don't think the dealer checked it after they found a bolt loose on the transfer case and now my truck is shifting weird...
Old 12-20-2005, 01:51 PM   #12 (permalink)
Bhudda454's Avatar
iTrader Score: 4 reviews
Send a message via Yahoo to Bhudda454
Quad T.
I am not sure if my worn out 2004 is the same as some of these newer fellas, but I can pull the dipstick and check my fluid. It does not have a pull handle like old style, and it does look like it is bolted, but it does pull out. I checked the hash marks just like old way.
I would be banging on the hatch at the dealership in the morning even if you are out of warranty. That leak is going to burn up your trans, and I doubt they woudl voluntarily say that it was their fault. Make them check the level, and then show you why it was leaking. If you have been in there for a leak before, and they said it was something else, they should have included in writing why they thought your trans was not the issue. You have doen your part as the owner, not your fault if they don't document it properly and have to recheck/replace it.
SOLD2008 Crew Cab SE Long bed 4x4
2011 Kia Sorento AWD - UAV Predator
OLD HOTNESS
NEW SEXY
Bhudda454 is offline   Reply With Quote
Old 12-20-2005, 01:59 PM   #13 (permalink)
Sammy Sandbag's Avatar
iTrader Score: 11 reviews
My '04 had a bolt on the dip stick like everyone has mentioned. I still removed it and checked it myself last week when I was doing some other MX (oil change, coolant top off, wiper fluid top off, tire rotate.)
-Counsel Yourself
2009 Blizzard Pro-4X
Sammy Sandbag is online now   Reply With Quote
Old 12-20-2005, 02:00 PM   #14 (permalink)
Triple S's Avatar
I'm off tomorrow so I'll do this in the daylight.
This sentence still confuses me To check fluid level, insert the ATF level gauge until the cap contacts the end of the charging pipe, with the gauge reversed from the normal attachment conditions as shown.
I agree with ya 454. I have to be proactive because I'm planning to keep this thing for a decade like I typically do with my trucks. I do not know if the tranny is leaking, to me it looked like it was only the transfer case, but a fluid check is the way to find out. And believe me, if I check it and I think it is low, I'm off to the dealership on my day off because I do not want to damage the tranny...
Old 12-20-2005, 02:04 PM   #15 (permalink)
Bhudda454's Avatar
Good the hear. about the proactive approach. I had an old K5 that used to leak the tranny fluid into the transfer case and then it leaked it out, but for the most part these things are two completely seperate items.
I think by gauge reversed they mean that the Hash Marks are only on one side.
OLD HOTNESS
NEW SEXY
Advertisement
SEO by vBSEO 3.3.2
