Old 08-02-2004, 02:22 PM   #1 (permalink)
Dual Climate Control on Nav....
A couple of times, a symbol has popped up in the lower corners of the nav sys. One side says "Driver" the other "Passenger". Underneath them is like a temp gauge. Does the LE have dual climate zones? I can't seem to get this up on my own.
If not, what are these symbols?
CyBwRBill is offline   Reply With Quote
Old 08-02-2004, 02:26 PM   #2 (permalink)
TriKKy's Avatar
No it doesn't have dual zone, and yes I know EXACTLY what you are talking about. It makes me wonder if you couldn't actually add it since the software seems to be there... What I haven't figured out is exacltly when and why they pop up.
1.
Old 08-02-2004, 02:28 PM   #3 (permalink)
The Armada has the dual zones.
Old 08-02-2004, 02:31 PM   #4 (permalink)
TriKKy's Avatar
Think it can be added? I'm willing to bet yes.
1.
Old 08-02-2004, 02:45 PM   #5 (permalink)
The nav system on the armada/titan are the same.
wirelessness is offline   Reply With Quote
Old 08-02-2004, 03:42 PM   #6 (permalink)
rrumaner's Avatar
Send a message via ICQ to rrumaner Send a message via AIM to rrumaner Send a message via MSN to rrumaner Send a message via Yahoo to rrumaner
I have mentioned that in the past and also talked to the service people about it. It stems from the computer and there appears to be a glitch in the system that occasionally makes the Titan think it is an Armada.
I was able to reproduce this for the dealer one day and they documented it. Eventually they might put out a TSB to fix it, but as it is not causing any safety problems, it might take a while.
I also got the temperature display on the top of the Nav screen just below the clock once in a while. It always shows as 32 degrees because there is no connector to make it work properly. Too bad it couldn't be tied into the mirror indicator.
Roy Rumaner
Any questions about the site etc. Lets us know!
rrumaner is offline   Reply With Quote
