Flex Fuel E85 - Nissan Titan Forum
post #1 of 11 (permalink) Old 12-25-2011, 02:52 PM Thread Starter
TitanATX's Avatar
iTrader Score: 0 reviews
Flex Fuel E85
So I just got a 2009 LE with the flex fuel motor. I have not used any of the E85 fuel yet and before I do I just wanted to ask if their are any negative issues associated with that kind of gas. Any comments would be great. Thank
TitanATX is offline
Advertisement
post #2 of 11 (permalink) Old 12-25-2011, 03:07 PM
smiller51283's Avatar
Re: Flex Fuel E85
My buddy had a S10 with flex fuel set up and it provided more power but less mileage when he used the E85.
2005 2wd CC Titan SE
2.5" PRG Level Kit and Bilstein Hd shocks
17" Method Race Wheels 4.75 BS
BFG Rugged Terrains 285/70r17
smiller51283 is offline
post #3 of 11 (permalink) Old 12-25-2011, 04:41 PM
Bigdog05's Avatar
Re: Flex Fuel E85
YES MORE POWER BUT THAT STUFF IS NASTY ON THE FUEL PUMPS If your fuel pump is in the tank then watch out e-85 is hell on pumps because the pumps plastic housing don't like and if you don't use a cleaner often you well see slow starts and less miles.on my third pump Nissan spec on them is my truck has 146000 on it. 05 cc le off road big tow .
Just my .cent
Bigdog05 is offline
post #4 of 11 (permalink) Old 12-25-2011, 06:00 PM
Rolex's Avatar
Re: Flex Fuel E85
Probably 20-25% less mpg. Anecdotally I also noticed that my Titan took longer to start on the E85.
The above post is my opinion....nothing more.
2008 Pro4X Big Tow, Prodigy brake controller, DVD, Navigation, leather, sunroof, Homelink, Nissan bug shield and sunroof shield, Nissan nerf bars, factory bed liner & utilitrack, BDPP tune, Injen CAI, PRG level kit, 33'' Nitto Ridge Grappler tires, UnderCover tonneau, 20" ZeroDark LED light bar in front, ZeroDark LED pod reverse lights flush mounted into rear bumper, RF stereo, Grover 1510 Stuttertone air horns with 5 gallon tank and Viair 400C compressor.
Rolex is offline
post #5 of 11 (permalink) Old 12-25-2011, 06:12 PM
Carbeaux's Avatar
iTrader Score: 12 reviews
Re: Flex Fuel E85
Reduction in mileage without an equal reduction in cost.
E85 has about a 28% lower energy density than regular gas which you can use as an indicator of how much worse your mileage will be. So, if you're not getting the E85 for 28% less than regular, skip on it. Unless of course you're just tree hugging, and if so, knock your socks off but expect to fill up quite a bit more frequently.
Hook 'Em!
AKA TroubleWhore™AKA HitAndMissWhore™AKA RockyWhore™AKA SigPicNaziWhore™
"Be polite, be professional, but have a plan to kill everybody you meet." - Gen. James 'Mad Dog' Mattis
2016 Super Crew, Platinum, 4WD FX4 Bought by me on 01/05/16
Carbeaux is offline
The Following 2 Users Say Thank You to Carbeaux For This Useful Post:
bestatchess (12-25-2011), nightowl (12-25-2011)
post #6 of 11 (permalink) Old 12-25-2011, 07:06 PM
NBhunter80's Avatar
Re: Flex Fuel E85
Just my .cent
The flex fuel Titans have a different fuel pump, and different fuel system components which are designed to withstand the added stresses of running E-85. If you are running E-85 in a non-flex fuel titan, then no wonder you are burning up fuel pumps. All the gas up here has at least 10% ethanol, and I have never had any fuel system issues in my '05 LE offroad big tow Flex Fuel with over 100k miles.
2005 Titan LE King Cab 4x4 Offroad Big Tow FFV.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, LT315/70r17 Kelly Safari TSR tires on OEM OR 7-spoke 17" rims, Rough Country 3" lift, 1" rear block, Bilsteins 5100s front and rear, 2011 Pro4x rear end, Axle vent mod, 2 degree timing advance, NGK Iridium spark plugs, Stock Airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top D34 battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
2012 Nissan Rogue SV AWD - Wife's ride
NBhunter80 is offline
post #7 of 11 (permalink) Old 12-25-2011, 08:18 PM
iTrader Score: 4 reviews
Re: Flex Fuel E85
No tree hugging benefits, either. Just a complete scam.
E85 vs. Gasoline Comparison Test - Edmunds.com
Ethanol may cause more smog, more deaths, study says | ethanol, jacobson, smog - News - The Orange County Register
http://www.stanford.edu/group/efmh/j...perEST0207.pdf
bestatchess is offline
The Following User Says Thank You to bestatchess For This Useful Post:
Rolex (01-01-2012)
post #8 of 11 (permalink) Old 12-25-2011, 08:28 PM
Carbeaux's Avatar
Re: Flex Fuel E85
I think he's from Austin where they do a lot of bassackward things in the name of keeping it weird.
Hope you don't want to actually drive yourself to the F1 race and park, for example. But there are showers for the folks who bicycle to the event.
Hook 'Em!
Carbeaux is offline
The Following User Says Thank You to Carbeaux For This Useful Post:
jaws8817 (02-02-2012)
post #9 of 11 (permalink) Old 12-27-2011, 05:22 AM
iTrader Score: 1 reviews
Re: Flex Fuel E85
Just wait, the government will mandate a lot more ethenol in fuel. It is no longer about the environment, but how to subsidize these massive agrigultural industries and line the pockets of beaurcrats and CEO's with revenue.
~Mark
2009 Titan SE CC- 325/65/18 Nitto Terra Grapplers / MB TKO's Wheels / Westin Bull Bar/ ProComp 6" Lift/ Bilstein 5100 fronts / 5125 Rear / RC Traction Bars / Borla ProXS / Cajun B-Pipes / BDGT / Airaid MXP CAI
VQP0WER is offline
The Following User Says Thank You to VQP0WER For This Useful Post:
post #10 of 11 (permalink) Old 12-29-2011, 01:26 PM Thread Starter
TitanATX's Avatar
Re: Flex Fuel E85
I am not so much concerned with the environmental benefits of the E85. I just wanted to make sure that their were no major issues with using that fuel. It runs about 50 cents cheaper per gallon at the HEB near my house but it sounds like you get less miles per gallon so I would be filling up more often. Oh well its nice to have the option and to know that the flex fuel engine will handle the ever increasing % of ethanol that is being added gas.
TitanATX is offline
post #11 of 11 (permalink) Old 02-02-2012, 04:01 PM
jaws8817's Avatar
Re: Flex Fuel E85
Yeah, I've been eyeing the E85 at the HEB here in Schertz now that gas is climbing back up there. It's $.30/gallon less than regular unleaded. And I work in construction so I've seen the 'Green Building' BS firsthand. You can build a bike rack and shower room to get a LEED point. Once the building is LEED certified I guess you get a warm feeling? Not sure what else it's good for. I took a picture of my Titan last week at the parking garage at the Pearl Brewery...in a spot with a sign that said "for low emitting/fuel efficient vehicles." Kiss my V8!
jaws8817 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Flex Fuel 900King Titan General Discussion 43 05-27-2010 03:31 PM
Flex fuel VS reg fuel engine surfintitan68 Titan Engine, Transmission & Drivetrain 8 10-16-2009 09:30 AM
Flex Fuel? Country_Boy2493 Titan General Discussion 4 10-29-2008 10:23 PM
Flex Fuel E85 9sec95autoTT Titan General Discussion 16 11-28-2007 09:35 AM
Any of you Titan owners have the Flex Fuel option and running E85 fuel??? kickinasphalt Titan General Discussion 16 12-03-2005 06:00 PM
You may post new threads
You may post replies
