Old 08-06-2004, 08:38 AM   #1 (permalink)
Question Hmmm, this is interesting
Already bought a Titan. But previously thinking about the Armada too, so I went to edmunds.com and compare the two. SE, 2WD
Overall, pretty close matchs, only thing that puzzle me is both of them are using the same engine, right?
But on Armada, the torque is 385 ft-lbs. And on the Titan it's 379 ft-lbs.
And Armada, max towing is 9100 lbs Vs Titan 9400 lbs !!!!!
Would have thought more torque mean more towing?!!
And why diff in torque in the same engine?
Both got the same 305 HP.
2004 Titan SE CrewCab 4X2
SE Popular w/bench
SE Utility Bed Package
Truxedo bed cover
Painted bug shield
OEM step rail
OEM sliding bed extender
Born on 7/14/04
Home on 7/23/04
htn123 is offline   Reply With Quote
Old 08-06-2004, 08:55 AM   #2 (permalink)
adjmcloon's Avatar
I would guess the Armada is heavier- thus the lower tow rating. No idea about the torque question though.
adjmcloon is offline   Reply With Quote
Old 08-06-2004, 09:07 AM   #3 (permalink)
GETSOMZ28's Avatar
What gears is the Armada running?
Scott
Old 08-06-2004, 10:04 AM   #4 (permalink)
The armada has slightly higher compression or timing advance (can't remember exactly which it is)...
bvstone1 is offline   Reply With Quote
Old 08-06-2004, 10:08 AM   #5 (permalink)
JMC
JMC's Avatar
The lower tow rating may be due to the independent rear suspension on the Armada instead of a straight axle.
JMC is offline   Reply With Quote
Old 08-06-2004, 12:14 PM   #6 (permalink)
adjmcloon's Avatar
I bet you're right JMC.
On the "clunk" thread I was thinking "hmm..I have no rear-wheel hopping going on on the freeway." I had forgotten about the different rear suspension on the Armada.
It sure does help towing! My 6x12 tandem axle cargo (#5000) feels likes it's barely there.
