question for you guys. I just purchased a titan last saturday and wad wondering . does the seat , pedal mirror memory cause excessive wear to the motor. it only seems obvious to me that everytime you turn the vehicle off the seat moving back would cause prematur wear to the motor. I just traded a 02 maxima for this truck so I'm trying to learn some stuff from you guys that had yours or a while. Tanx.
Any type of device you use in your Titan will wear down. Its a known mechanical fact, you can't avoid it unless you don't drive it . As for seats moving back and forth for your convience, i haven't found anything that says you can turn it off. Just get used to it and set your seat memory configuration correctly before you mess up the default factory settings like I did.
Little annoyances...got it fixed. the seat kept on forgetting my config's.
Nissan Titan LE 4x2 CC
Purchased: Feb 2004 Miles to date: 74,000 (Since Feb, 15 2004)
Mods: Banks Cat Back Exhaust System, K&N with arbox mod, Front Air Dam, Custom bed cover, AC/DC interior conversion, PSP/Ipod Dock http://www.phillipyang.com
It says in the manual if you don't have the NAV system, you can take it to the dealership and they can turn off that feature. BTW, they can also adjust the timing on the Auto Headlights so they don't take 3 minutes to turn off.
CC LE Smoke
JBA Cat Back Exhaust
K&N CAI
10" Fosgate He2
i talked to the dealer where i used to live about turning off the egress feature alone. he told me that i would lose all seat memory function if they turned it off. is this true? i hate that my seat moves while im getting out of my truck. thanks for any info....
no i havent yet...dont wanna spend the money on that since i just moved to AZ and i need to save money to buy a house...when mine sells in minnesota that is.
I had the same thought... And had the dealer turn off the auto feature.
the seat memory feature still works the same......... all o.k. It only took maybe 5 min... Just done it with a handheld programmer in the parking lot.
FWIW, normal use of the seat motors shouldn't cause excesive wear. I have a 93 Volvo 854 with power front seats, and after 11 years it works just as good as the day off the lot.
Fair enough but did you move your seat everytime you got in and out the vehicle, which for me is at a minimun 4 times per day.
The way, i figure, maybe after five years or so, IF i still have the truck, the motor MIGHT go out. At that point, I'll pony up the whole $50 or whatever it is an put a new motor in. In, the meantime, no worries.
CC LE Smoke
K&N CAI
10" Fosgate He2
