Oil pressure gauge always on high - Nissan Titan Forum
Old 02-05-2012, 05:45 AM   #1 (permalink)
iTrader Score: 0 reviews
About a week ago I noticed my pressure gauge is always on high. Is this from an over fill by grease monkey and if so what damage can it cause? Truck seems to run fine but I swear that needle use to react depending on how much gas I gave it.
krc333 is offline   Reply With Quote
Advertisement
Old 02-05-2012, 11:45 AM   #2 (permalink)
iTrader Score: 3 reviews
Re: Oil pressure gauge always on high
Yes, too much oil pressure is bad. You can open the system while it's running (take the cap off, put a rag on) and see if it goes down. My bet is that the gauge or the sender has gone bad. When you're idling it should be reasonably low. What does your oil level say?
jdmartin is offline   Reply With Quote
Old 02-07-2012, 11:39 AM   #3 (permalink)
Thanks, i'm going to check my oil level tonight when i get home and see. How do i know if that sensor is bad? Is it hard thing to replace? Does it throw a code?
Old 02-07-2012, 01:38 PM   #4 (permalink)
OFELIPE's Avatar
turn the key to the "on/run" position, but dont start the truck, if the needle pegs without the engine running then your sending unit is shot.
StarvinMarvinWhore™
~ UPREV Tuned ~ JBA Headers ~ Banks Exhaust ~ Volant CAI ~
~ DDM 6k HID's Lows and Fogs ~
~ 2 American Bass XFL 10's ~ Soundstream Rubicon 2500D Mono Block ~ 2/0g Wiring ~ 4g Grounding Kit ~ Custom FF Ported Box ~
~ SD_Titan 2in Seat Lift ~
~ Spring Tech Lowering Shackles ~ Blacked-Out Foose Spank 6 22's ~ 305/40/22 Nitto 420's ~
~ SD_Titan Headlight Mod ~ Grill Mod ~ JB LED Reverse Lights ~
OFELIPE is offline   Reply With Quote
Old 02-07-2012, 07:59 PM   #5 (permalink)
PAPARYNO's Avatar
iTrader Score: 1 reviews
mine does this only until the tranny heats up
CAMS CAMS CAMS CAMS CAMS CAMS CAMS CAMS CAMS CAMS CAMS
UPREV! OG
06 TITAN LE CC 4X2 Loaded w/Nav & DVD,BT, ValentineRD, G-Tech,
AEM BruteForce CAI, Stillen LongTubes, Jwt Cams, Uprev, Tranny Line Pressure Mod, Level 10 Tranny, 08 Brake Upgrade With Hawk LTS Pads and Goodridge stainless steel brake lines, 08 Intake Manifold, TB Bypass, DDM HID 8K Lows and Fogs, Stillen SwayBars
F&R, Magnaflow 50 Duals, TruTrac,NX 100Shot w/RemoteOpener
BC 0-60mph 7.81sec. 1/4mile 16.01sec.@87.0mph (Top Speed 122mph)
AC 0-60mph 5.21sec. 1/4mile 13.65sec.@99.93mph
(Top Speed 140+mph)!!
Dynotech Dyno SAE #'s N/A Map 325.71 RWHP / 364.06 TQ (old Dyno 273hp/338tq)
GO NISSAN
They say O-FiveCC who but i say gweazel77 who
PAPARYNO is offline   Reply With Quote
Old 02-08-2012, 06:19 PM   #6 (permalink)
Cold starts no matter what outside temp until the engine warms all the way up, if I am not careful will peg the oil pressure gauge. The dealership said "oh thats normal" but Im not putting a lot of insurance in that statement, I just watch the throttle till shes completely warm. And this is with a K&N filter with royal purple synthetic 5/30.
Westy0507 is offline   Reply With Quote
Old 02-09-2012, 12:12 PM   #7 (permalink)
OFELIPE's Avatar
That's what mine did after I had my oil sending unit replaced
Sent from my Autoguide iPad app
StarvinMarvinWhore™
Old 02-15-2012, 06:41 AM   #8 (permalink)
Mo-Titan's Avatar
iTrader Score: 24 reviews
Hurt anything to drive around with a bad sending unit? Mine pegged out this morning, oil looks fine. If it stops raining I'll try turning just the key on, but my guess is the unit is bad, cause I shut the truck off and restarted.. same pegged gauge.
Titan Sold - 3-06-2012, Plan Z = '96 BMW Z3 - Traded 7-13-12 (Friday the 13th)
Mo-Titan is offline   Reply With Quote
Old 02-15-2012, 07:33 AM   #9 (permalink)
ArmyAviation's Avatar
iTrader Score: 5 reviews
his statement "Grease Monkey" said it all. yes over filling is bad, blow out seals and alot of blow by.
2008 SE CC 4X4 RED BRAWN w/popular package
Sirius Sportster 5
Spectre Performance Air Filter
Nitto Terra Grapplers
Bilstein 5100's
Activetune Grounding Kit Red wires
24" Magnaflow Cat-Back
Nissan Steprails Black
2* Timing
Nissan Bug Shield
OEM Weather Floor mats
Current miles 129K and still going strong
PINK JETTA WHORE
ArmyAviation is offline   Reply With Quote
Old 02-15-2012, 11:05 AM   #10 (permalink)
vilim12's Avatar
feed it cheerios
2008 Nissan Titan Pro-4x CC LWB Smoke
UNDER CONSTRUCTION
vilim12 is offline   Reply With Quote
The Following 2 Users Say Thank You to vilim12 For This Useful Post:
FREDC (08-17-2012), Mrlunchbox (03-01-2013)
Old 02-15-2012, 11:31 AM   #11 (permalink)
Banned
JTeeter04's Avatar
Originally Posted by vilim12 View Post
feed it cheerios
Dadum chss
Sent from my Autoguide iPhone app
JTeeter04 is offline   Reply With Quote
The Following User Says Thank You to JTeeter04 For This Useful Post:
vilim12 (02-15-2012)
Old 02-15-2012, 11:33 AM   #12 (permalink)
OFELIPE's Avatar
Not going to hurt anything with the sending unit out. Just make sure the pressur isnt actually high. ignition on/engine off will tell you.
You could also try a guage reset if it happens to be physically stuck.
Putting the cluster into test mode-
With ign off press and hold the odo. reset button, now turn the key to ON while continuing to hold down the reset button.
this will take you to a test screen, now everytime you push the reset button it will take you to a new screen, do this till it test all needles.
StarvinMarvinWhore™
Old 02-15-2012, 11:44 AM   #13 (permalink)
moonlight's Avatar
Has anyone figured out what all those other readings are when you run the test mode on the cluster? I figured out how to read live RPM and a few others but I'd love to know what all those other numbers & readings are.
2005 Infiniti QX56 -- Project Moonlight
Car Domain Youtube Vimeo
Audio: Subs: 2 JL 13W7 Mids: 2 JL C5 speakers Amps: 2 JL 1000/1, 1 JL 300/2, 1 JL 400/4 Deck: Pioneer AVIC Z110BT Aux: PS3, MacMini, Ipod Screens: re-mount OEM display to roof, touch-screen Mac display, Pioneer Deck custom mount, two 8-inch swivel-mount flip-down screens in second row (headrests to follow )
Interior: Custom upholstery, headliner, speaker mounts, speaker cover, sub box & amp rack, Champagne bottle & hidden mousepad... i think thats all
Muscle: AEM Brute Force CAI, Stillen SC, Stillen Ceramic headers & b-pipe, full custom true-dual exhaust, B&M Tranny & Oil cooler kit, Stillen Big Break Kit (front) & 3 Kinetik Batteries (2000W+ 2*1200W), *2 Magnaflow dual 3" tips
give me a VK56, or some Rossi's, either way i wanna go fast till I hit terminal velocity, ride hard till it burns, and carve till the rest are all behind me.
moonlight is offline   Reply With Quote
Advertisement
oil preasure gauge reading high El Mamito USMC Titan Problems & Dealer Service 5 11-14-2011 03:45 PM
oil pressure gauge going up wmg Titan Engine, Transmission & Drivetrain 3 07-20-2007 04:27 PM
Oil Pressure Gauge Pegs On High Mark FlimFlamMan Titan Problems & Dealer Service 20 01-12-2006 02:58 PM
AFE & OIL PRESSURE GAUGE 20TITAN04 Titan General Discussion 6 10-15-2005 05:43 PM
Temp gauge ran high while trailing on 4LO alvinispogi Titan General Discussion 3 07-16-2004 01:20 PM
SEO by vBSEO 3.3.2
