Old 08-08-2004, 08:47 PM   #1 (permalink)
Angry Rattle in dash!!!
I have owned my Titan now for 2 weeks (awsome truck). The day after I bought it though, I started getting a ticking/rattle/creaking sound coming from the right side of my dash. it almosts sounds as if theres a loose bolt and the dash has just enough play to put stress on the plastic and cause a creaking noise. I took it to my dealer and they gave me a bunch of bs saying that it will go away with time. I now, its a horible description but has anyone else experenced the problem and figure out whats causing it?
Kingofthebling49 is offline   Reply With Quote
Old 08-09-2004, 08:20 AM   #2 (permalink)
adjmcloon's Avatar
I've managed to kill it (mostly) in my Armada. Do you have a piece (the auto-headlight sensor is attached to it) on top of your dash right by the windshield? I popped it up and pretty much coated the whole underside with one side of velcro everywhere it touched the dash. Popped it back in, and the popping/creaking noises are gone.
It used to do it pretty bad if I left my Armada in the sun and got the dash hot. Now if I could only kill the last tiny creak from the rear gate, all would be well.
adjmcloon is offline   Reply With Quote
Old 08-09-2004, 08:39 AM   #3 (permalink)
Gig'em's Avatar
Send a message via AIM to Gig'em
I think I have the same squeak/creak. Its on the passenger side of the dash and sounds like its down near the vent. My girlfriend pushed on it in several different locations, but to no avail. If anyone fixes this, I want to be the first to know.
I'd rather have a bottle in front of me than a frontal lobotomy.
Gig'em is offline   Reply With Quote
Old 08-09-2004, 05:36 PM   #4 (permalink)
Thats exactly were the sound seems to be coming from. Glad to know I'm not the only person with this problem
Old 08-09-2004, 07:57 PM   #5 (permalink)
I had a rattle in that area and added some foam in the passanger side corner close to the windshield and that stopped it for me.
Biscuit'sTitan is offline   Reply With Quote
Old 08-09-2004, 08:52 PM   #6 (permalink)
Did you have to remove the dash in order to insert the foam, if so how did you go about it? Thanks
Old 08-09-2004, 09:04 PM   #7 (permalink)
TallTexan's Avatar
Check the passenger side speaker on top of the dash and check your glove box door. I read one poster said his hood was sqeeking due to rubber spacers under hood not screwed out to touch and support the hood .
Old 08-09-2004, 11:45 PM   #8 (permalink)
DallasTitan's Avatar
Search button: .... dash rattle .....
Number of threads found: 43
An example of a related thread: Squeeks and rattles...
________________________
2004 Titan SE CC 4X2, Built 11-15-2003
Purchased 12-12-03
Galaxy Black, Popular SE pkg, Capt. chairs/gated shifter, Factory Fog lights, UtiliTrac/Bedliner pkg,PRG Leveling Kit Front and Rear
DallasTitan is offline   Reply With Quote
Old 09-13-2004, 06:15 AM   #9 (permalink)
Same problem here! Rattle in center of dash coming from radio area and passenger side.
Please help! Nissan has not been able to fix.
kbutton is offline   Reply With Quote
Old 09-13-2004, 07:09 AM   #10 (permalink)
Mine goes away when I turn the HVAC system off, so I was thinking it was the fan or some part of the vent(s) rattling when I have the system on...
I'll try others responses too, but try turning off the air completly (to 0) and see if it goes away...
SmokenTitan is offline   Reply With Quote
Old 09-13-2004, 01:27 PM   #11 (permalink)
I have the same noise coming from the same spot. I can make it go away by putting some weight on the right front corner of the dash.
I would like a little more detail about how the foam was applied.
Davace97 is offline   Reply With Quote
Old 09-13-2004, 01:38 PM   #12 (permalink)
I just picked up my Titan a few weeks ago, also have the rattle. I am taking it into the dealer on Friday, I will let everyone know what they tell me.
Premier is offline   Reply With Quote
Old 09-15-2004, 03:34 PM   #13 (permalink)
I also have a noise coming from the right side dash, by the ac vent. It sounds sort of like if I had a couple of washers in a cup, and it sounds only when I drive over rough roads or bumps. The noise has nothing to do with the engine or acceleration like other posts I've read (I even turned off the engine on a bumpy road and could still hear it.)
I took the glove compartment out and removed the fuse cover and had my wife drive around (can you believe I let her drive it?) while I stuck my head in and around that area. I tried moving the wire bundles and stand-offs behind there but I was not able to stop the noise. I did find out that I can hit the dash with the base of my palm with the truck stopped and cause a similar, much less noticeable noise.
I am convinced that the noise is coming from a steel tube, about 2 inches in diameter, that goes all the way across the dash. You can see the tube by looking past the glove compartment door at a slight up angle. This tube provides some attachment points for the Dash and you can see the wire stand-offs welded to it. I noticed that the tube has punched holes in it and I bet the punched metal is still in the tube and causing the noise I hear.
Does anyone know if there are any wires that run inside this tube? I am tempted to drill out some of those punched holes enough to get a magnet in there and try to chase those pieces out. Another option is to fill the tube with some expanding foam or something that would kind of glue the loose pieces in place.
2004 Nissan Titan SE Crew
Big Tow
SE Popular Package
Born in June
Flafisher is offline   Reply With Quote
Old 09-15-2004, 04:52 PM   #14 (permalink)
TallTexan's Avatar
Most of the rattles found in that are have been from a pillar plastic where it rattles against the windshieldor against the dash itself. Press foan pieces with a sharp screwdriver into the cracks and that will stop most of them. Also had a mirror rattle that sounded like from the vent. Good luck!
Old 09-15-2004, 05:14 PM   #15 (permalink)
I too had dash rattle noise coming from the center to center/right. I was able to cut 99% of it out after scooting close to the windshield, and pressing on the defrost vent; of course I drove this way only for troubleshooting purposes! After telling the local Nissan tech of this, they packed the defrost vent area with foam, which has cut down considerably if not totally on the rattle noise.
LE CC 4x4 BT OR
Rondretti is offline   Reply With Quote
