Old 08-11-2004, 08:40 AM   #1 (permalink)
ttammunek04's Avatar
Wiring harness question.
I have a question. My titan doesn't have the BT pkg. and I'm looking to buy a wiring harness. I won't be needing relays for electrical brakes. Could someone tell me what I need to buy and, if any local auto parts stores e.g. Autozone, Napa, O'Reilly, Car Quest, Advanced, etc..... would have them in stock yet. I crawled under the "TANK" and all I have that even resembles a wiring harness would be a plug that is about as big around as a tube of grease or a little smaller. I think that this is the plug for the harness, or is it? Any help would be appreciated.
2004 Nissan Titan SE KC
2006 Polaris Sportsman 500 EFI
Mods:
K&N Drop in Air Filter
Flowmaster Delta Flow 40 series exhaust
Custom Built Diamond Plate Drop-in Tool Box
AVS Bug turd deflector
P265/70/18 Firestone Destination A/T's
ttammunek04 is offline   Reply With Quote
Old 08-11-2004, 09:17 AM   #2 (permalink)
Nissan harness
You should just buy the harness from nissan. Plug it in. Nissan has good
towing stuff. I am not sure if they sell just the plug going to wires or
the plug wires and round 7 pin trailer plug. You didn't say but did you
need the four pin connector or the 7 pin round connector for your trailer?
Zardoz
Zardoz is offline   Reply With Quote
Old 08-11-2004, 09:19 AM   #3 (permalink)
4 pin will be all I need. I think that I already have the main plug. It is located on top of the rear bumper, facing away from the truck.
Mods:
Old 08-11-2004, 08:48 PM   #4 (permalink)
mick3643's Avatar
you will need to buy the plug that the harness plugs into from nissan. That gives you the 7 pin connection. than you can go to walmart and buy the 7 to 4 pin adapter. You will also need to buy the light relay to make the lights work. one is about 20.00 bucks the other is around 30.00. i think the light relay is the cheaper one. I dodn't know the difference and bought both. wasted 30.00 as i don't use the brakes either.
2005 2wd SE Crew Cab
air bags
turbo muffler
Scan guage
Bd tuner beta
mick3643 is offline   Reply With Quote
Old 08-11-2004, 09:06 PM   #5 (permalink)
I dont have the BT but I did go to nissan and buy the hitch, it came with all the relays and I was able to put it on in about 5-8 minutes!! Very easy to install..Well worth the money, and it is just as factory looking as the ones with BT. Just dont have the trans temp guage, no big deal...
XE KC 4x4 Offroad (traded for 06 DodgeRam 2500 CTD 4x4)
My own Big Tow
Prodigy Brake Controller
Sirius Sat Radio
CB
Born on 3/26/04
04 Xterra,Airaid intake
aztitan4x4 is offline   Reply With Quote
