VK56 240sx s14 swap - Nissan Titan Forum
Old 03-06-2012, 07:24 PM   #1 (permalink)
iTrader Score: 0 reviews
Smile VK56 240sx s14 swap
Hey guys my name is julian i am working on a vk56 swap. I am nearing the end hopefully we are almost done with the fab work its jut alot of plug and play from here. If any one has questions or can give me help let me know i appreciate all knowledge
http://a6.sphotos.ak.fbcdn.net/hphot...28532099_n.jpg
Removing the KA
http://sphotos.xx.fbcdn.net/hphotos-...24640058_n.jpg
vk
http://sphotos.xx.fbcdn.net/hphotos-...27160134_n.jpg
first fitting
flywheel
http://photos-a.ak.fbcdn.net/hphotos...04576050_a.jpg
clutch
http://sphotos.xx.fbcdn.net/hphotos-...68932761_n.jpg
transmission shifter relocation
http://sphotos.xx.fbcdn.net/hphotos-...21179764_n.jpg
tranny and engine with adaptor
http://sphotos.xx.fbcdn.net/hphotos-...28171919_n.jpg
time to build some mounts
http://sphotos.xx.fbcdn.net/hphotos-...65858978_n.jpg
engine clean up
http://sphotos.xx.fbcdn.net/hphotos-...32690213_n.jpg
http://sphotos.xx.fbcdn.net/hphotos-...99871316_n.jpg
jramirez63 is offline   Reply With Quote
The Following 4 Users Say Thank You to jramirez63 For This Useful Post:
gweasel77 (03-07-2012), MilenkoGT (03-09-2012), moonlight (03-07-2012), VinylImagez (03-08-2012)
Advertisement
Old 03-06-2012, 07:35 PM   #2 (permalink)
Re: VK56 240sx s14 swap
Interesting build. I saw someone on you tube is running a supercharged VK in a G35. it would be interested in hearing how it affects the weight distribution in a S14.
My S13 with SR20 always felt so balanced, especially slinging it sideways through a turn.
big_pErm is offline   Reply With Quote
Old 03-06-2012, 07:39 PM   #3 (permalink)
I think the weight distribution will work out really good, We have the engine sitting as low as possible without the oilpan hitting the floor, and the engine is barley a cm from the firewall. I cant wait to get it back on the track
Old 03-06-2012, 08:43 PM   #4 (permalink)
alot of people think that the oil pan wont clear , but with a couple hours of fabrication there is no need to spend a large amount of money on custom aftermarket parts.
The Following 2 Users Say Thank You to jramirez63 For This Useful Post:
gweasel77 (03-07-2012), moonlight (03-07-2012)
Old 03-06-2012, 09:18 PM   #5 (permalink)
Yoshi's Avatar
The reason I can't do what you did is because modifying the firewall was greater than an 18 in diameter is against the fd rule book. :/ Which means I can't set the motor that far back.
Definitely looks great though! It's good to see more people working on these motors!
What are you doing about your brake master cylinder? And what ecu are you running?
-bump steer makes driving more exciting- (>_<)
Yoshi is offline   Reply With Quote
Old 03-06-2012, 09:25 PM   #6 (permalink)
yes i carefully read both xdc and fd rulebooks. modifications to the firewall are totally allowed as long as the firewall is no wider than 18 inches, which mine isnt. what we did is completley dropped the center section of the subfram 2 inches so that the oil pan could clear in a nice location in which the transmission can fit under the 18 inches. ill check to see if i can get a clear picture.
• Dimension A: Tunnel Width May be no wider than 18 Inches
• Dimension B: Minimum dimension of 10 inches between the bottom of
the windshield and the top of the transmission tunnel.
• Dimension C: Modifications of the driveshaft tunnels behind the
transmission tunnel taper vertical plane should not exceed an overall
width of 10 inches.
• Dimension D: Modifications to driveshaft tunnels behind the
width of 10 inches.
• Taper Length: (from the firewall to the end of the transmission tunnel
into the beginning of the driveshaft hump) may be no longer than 36
inches.
• No part of the engine casing may cross the vertical plane of the original
firewall into the transmission tunnel.
• No other modifications may be made to the vehicle chassis, frame, or
uni-body unless otherwise specified in these rules.
• Any holes in the firewall must be of the minimum size for the passage of
controls and wires, and must be completely sealed to prevent the
passage of fluids or flames from the engine compartment to the ****pit.Formula Drift Professional Drifting
2010 Rules and Regulations
35 Version 1.0 10/27/2009
8.3.4 Front cross member and/or front or rear sub-frame
Front and rear sub-frames and cross members must be stock and
available on the exact model that is competing in Formula Drift. The
subframe must also be mounted in the exact stock location, without
being moved in any plane.
Front subframes may only be modified to directly allow for oilpan /
starter clearance and steering rack relocation. The front subframe must
retain intact on at least one major member on one face that spans the
entire width of the subframe, thereby keeping the original dimensions of
the subframe intact. Any other modifications, cutting, welding,
strengthening, etc is not allowed.
Rear subframes may only be modified to allow for mounting or
relocating a differential. The rear subframe must retain at least one
major member that spans the entire width of the subframe, thereby
keeping the original dimensions of the subframe intact. An
The Following User Says Thank You to jramirez63 For This Useful Post:
Old 03-06-2012, 09:29 PM   #7 (permalink)
Yoshi's Avatar
I would be interested in seeing more.
Also how is the shifter location with the motor that far back? And how does the oil filter fit with the sway bar?
Old 03-06-2012, 09:30 PM   #8 (permalink)
gweasel77 (03-07-2012), VinylImagez (03-07-2012)
Old 03-06-2012, 09:32 PM   #9 (permalink)
the shifter is about 4inches from stock. and the oil filter will not fit, but the solution for that is an oil filter relocation kit which is only like 30bucks.
Old 03-06-2012, 09:37 PM   #10 (permalink)
Yoshi's Avatar
That's what I figured. Are you eliminating the stupid water cooler deal?
Old 03-07-2012, 12:51 AM   #11 (permalink)
I forgot to answer your previous question with the brake booster, but i bought the chase bays brake booster eliminator.
Old 03-07-2012, 03:10 AM   #12 (permalink)
gweasel77's Avatar
iTrader Score: 6 reviews
Great info guys!!! Thank for the pics too!
2005 NISSAN TITAN SE KC
IRC VK56 TEAM MEMBER
performance:
UP/REV CUSTOM TUNED
4" Airaid MXP CAI w/ GW77 4" Ram-Air Mod / TB Bypass Mod / FT90 Kit / LS7 TB / '08 IM / CSF Race Rad. / Trans. Cooler / Nismo LT Header's / Berk Tech SS B-Pipes w/ Magnaflow Hi-Flows / 2.25"-3" Flowmaster Y-Pipe / Borla XR-1 Muffler / "Gatorback" Serp Belt / Relentless RPM Catch Can / Detriot TruTrac / ActiveTuning Grounding Kit / Burnout Mod / LP Mod / MT ET Street P295/45R/17 DR's / Mobil1 EP 5W30 / 75W140
exterior/suspension:
Ruff Racing R286 22"x9.5" Chromes w/ 305/45/22 Yokohama Parada Spec-X's / Slotted "cryo" Frozen Rotors / Hawk LTS Brake Pads / High Cap. Diff. Cover / Helwig RSB / Bilstein HD's / SpringTech 2" Drop Shackles / PRG camber bolts / Armada Air Dam / SolarGard Tint / Tow Hooks / Debadged
NEW PB: 1/4- 13.57 @ 98.51MPH w/ my BEST 60' EVER 1.88
New PB Dragtimes Page:http://www.dragtimes.com/Nissan-Tita...lip-25254.html
Need to install: PRG Street Traction Bars!!!
Next Mods: CAJUN PIPES!!!!
gweasel77 is offline   Reply With Quote
Old 03-07-2012, 04:52 PM   #13 (permalink)
these are the final mounts
gweasel77 (03-08-2012), VinylImagez (03-08-2012)
Old 03-07-2012, 04:57 PM   #14 (permalink)
ostaF's Avatar
iTrader Score: 2 reviews
This is cool! Looking forward to vids of her running.
ostaF is offline   Reply With Quote
Old 03-08-2012, 06:51 PM   #15 (permalink)
ready to start attaching everything
gweasel77 (03-09-2012)
Advertisement
Introduction/ VK56 240SX Build Yoshi Titan Performance Modifications 39 07-18-2012 03:16 PM
vk56 2006 350z 6spd swap vk Z Titan Performance Modifications 117 02-17-2012 04:52 AM
vk56 swap into 350z exhaust size? vk Z Titan Performance Modifications 24 05-18-2011 01:34 PM
SBF 302 going into my 240sx coupe! MilenkoGT Titan Pictures & Media Post 0 04-04-2010 10:29 PM
SEO by vBSEO 3.3.2
