In FL I would recommend either the mobi1 1 0w-40 or mobil 1 10w-30. Those two grades typically outperform mobil 1 5w-30. Yes the mobil 1 is typically a better choice then syntec or penz. synthetics, with the exception of german syntec 0w-30(another oil to consider, its what i run in my titan). Mobil 1 is a PAO base synthetic oil, penz, valvoline, syntec(exeption of 0w-30) are group III oils, although the law allows them to be called fully synthetic there actually not and therefore not worth the premium price when a pao synth. can be purchased for the same amount of money.
I've been really happy so far with the GC 0w-30, its acea A3 certified like the mobil 1 0w-40, its actually much thicker than mobil 1 10w-30 but still gives outstanding fuel economy and the option of extended drains. Plus its a year round oil even in the most diverse climates. I've gotten none of the valve train clatter that is typical with mobil 1 as well. Problem with this oil is availibiltity, wal-mart does not carry it but most auto zones have it, its the syntec 0w-30 and should say "made in germany" on the back. I wouldn't touch any other grade of syntec with a 10 foot pole, there totally different, not even made in the same country as one another.
04 Titan CC,BT,OR,4X4, 5333lbs, 15.42@88.79mph stock
Zoomers catback, 2* timing advance
