vent actuator???? - Nissan Titan Forum
Old 03-19-2012, 11:06 PM   #1 (permalink)
Nismo85z's Avatar
iTrader Score: 0 reviews
vent actuator????
Ssooooo I got the knock from hell :l and I've been reading up on the posts to which actuator it may be. But now I'm lost is there 3 or 2 actuators. I'm certain its not the one inside the dash, since I have control over the cold & heat. But my A/C is stuck on def and its hot as hell here in south TX. So I guess I'm asking is there only one on top of the gas pedal or is there 2? Also, I used to get the knocking from the passenger side, does that make a difference or is it just traveling through the vents. I've always ddone the work myself so any help is greatly appreciated.
Nismo85z is offline   Reply With Quote
Advertisement
Old 03-20-2012, 09:30 AM   #2 (permalink)
kbadger3's Avatar
iTrader Score: 3 reviews
Re: vent actuator????
I believe there are 2 of them on this truck. I have an 06 and there were 2 on mine, one above the gas pedal and one behind the glove box area on top of the assembly. Here is a link to a drawing of the system. 270 Heater & Blower Unit :: Body Electrical :: Genuine Nissan Parts :: Titan Parts (A60) 2004-2012 :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
When do you have the knocking? is it when you switch from defrost to feet and face or is it when you change the temp control ? Do you have control over your temp in the truck at all? If it is when temp is changed then it is the actuator behind the glove box area which I have read is a royal PIA. If it is when you change where the heat is going then it's the actuator above the gas pedal. I recently changed that one out and it cured my knocking that happened when I change from defrost to anything else. It was not terrible to do either, pull 3 bolts from the ECU i think and move it out of the way then there are 3 screws on the actuator, 2 on the bottom and one on top. THe 2 bottoms are 7mm I think and that top one is 5.5 mm I believe, I know it was different.
Hope I have helped out and good luck.
2006 Titan SE
Mods: Air Box Mod(gone), AIR Raid MXP intake, DIY Grill
Audio: Kenwood DDX-514, Bluetooth & iPod hookups, custom ported box w/ 2 10W3's, Kicker 1000.1
Interior: Beltronics RX-75 radar detector, Auto-dim Mirror w/ temp & compass, Seat Heaters, Viper 5501 autostart, all LED bulbs.
Exterior: Bull bar, KC-Hi Lites, 35 Watt HID Hi & Low Beams, 35 Watt HID Fog lights, Smoked LED Tail Lights, Smoked LED 3rd Brake light, LED Tailgate Bar, Dynomax dual exhaust kit...More to come
kbadger3 is offline   Reply With Quote
The Following User Says Thank You to kbadger3 For This Useful Post:
VballHerk (03-20-2012)
Old 03-20-2012, 02:56 PM   #3 (permalink)
VballHerk's Avatar
I just bought truck and it does the same thing.
The funny thing is, the part I need was sitting in my glovebox. So obviously the dealership knew of the problem.
Currently battling them over this.
VballHerk is offline   Reply With Quote
Old 03-20-2012, 03:01 PM   #4 (permalink)
iTrader Score: 2 reviews
I had this problem about 3 months after I got the truck. Still under warranty, got the stealership to fix. Took them about 4 hours... well that is how long it took them to call me saying it was done. On mine it was the one above the gas pedal too.
2010 SE
*Insert Clever Caption Here*
Bilstein 5100 all around. Front set to highest setting.
Debadged doors and tailgate.
Bully dog gt
Tinted front windows.
Kobalt low profile black toolbox.
Stubby antenna
Airaid MXP
nixx is offline   Reply With Quote
Old 03-20-2012, 03:03 PM   #5 (permalink)
VballHerk's Avatar
I just ran out to the truck, it sounds like its the one above the gas pedal. I think I'll just change it myself since the dealership is 5 hours away.
Old 03-21-2012, 05:08 AM   #6 (permalink)
Nismo85z's Avatar
Talking Re: vent actuator????
I FIXED IT!!! lol I found the actuator that was faulty, it was the one on top of the pedal. You could hear the whining from the actuator when it was on the vent, but when it was on defrost it would get quiet.......sssoooooooo I left it alone but I shifted the white plate myself, and viola I got my vents working again ^_^
Old 03-21-2012, 05:12 AM   #7 (permalink)
Nismo85z's Avatar
Thanks for all the input. And for kbagder3, I have control over the control of the A/C and heat. So I ruled that one out quickly, i just finally got a chance yesterday to work on it. Thanks once again.
Old 03-22-2012, 09:59 AM   #8 (permalink)
BearBrawn's Avatar
How did you "shift" the white plate?
I can see that the white plate is making the knocking sound approximately 90 seconds after turning the key to the OFF position.
Looks like it is not seating correctly as it completes the closing motion...
'04 Titan CC SE 4X4 ~ Red Brawn ~ Big Tow/Utility
'12 Dodge Durango AWD ~ Stone White
BearBrawn is offline   Reply With Quote
Old 03-22-2012, 10:22 AM   #9 (permalink)
Nismo85z's Avatar
Just pushed the left side up. Lay on your back and look up at it, push the left side up. I'm assuming that if yours is stuck on defrost as mine as, it should be down. So to get your vents back push it up and you'll hear it shift inside, and viola.
Old 03-22-2012, 11:07 AM   #10 (permalink)
BearBrawn's Avatar
Ok thanks - mine isn't stuck - it rotates to the closed position after turning the key to OFF - but at the fully closed position it clicks about 15 times - probably due to a missing tooth or something as described on here
Old 03-22-2012, 11:29 AM   #11 (permalink)
Nismo85z's Avatar
Possibly, mines been like that for about a year so it clwiyldbt click anymore. Oh well problem solved ^_^
Old 03-22-2012, 01:19 PM   #12 (permalink)
kbadger3's Avatar
That is exactly what mine was doing. I swapped out the actuator and the problem went away.
2006 Titan SE
Advertisement
Replacing vent control Actuator Shane06fl Titan FAQ & Howto Area 16 05-20-2013 04:26 PM
Actuator for Tailgate TiTAN- Titan General Discussion 2 10-31-2011 08:19 PM
ABS actuator install G-walker Titan Wheels, Tires & Brakes 0 02-04-2011 07:15 PM
bypass abs actuator? Hawaiianbasshead Titan Problems & Dealer Service 5 12-31-2010 09:33 AM
SEO by vBSEO 3.3.2
