Old 08-16-2004, 09:08 AM   #1 (permalink)
Tire/Wheel swap
I traded my 2001 GMC Yukon in for my Titan. I have some Goodyear MT/R tires on 16" American Racing rims that I put on my Yukon for our lovely Upstate NY winters. I would like to put them on my Titan as they only have about 4,000 miles on them. Is the lug pattern the same as the Chevy 6-bolt? Also, if the tires/rims will fit what are my options as far as the tire pressure sensors? The valve stems on the MT/R's cost me a boat load so I don't want to swap them. Thanks for any feedback.
Born on date 5/04
2004 SE Crew Cab
Off-Road w/E-locker
56,650 miles - Out of warranty and scared to death!
StumpZ is offline   Reply With Quote
Old 08-16-2004, 09:09 AM   #2 (permalink)
CaliforniaTitan's Avatar
Stump...
From what I understand...the lug pattern is the same...check your offset on your aftermarket wheels though...
As far as the valve stems....if you don't want the tire light, then your gonna need a set of sensors...
Edit: whoops..missed the 16" part....prolly not gonna work :-(
Chris
Old 08-16-2004, 09:16 AM   #3 (permalink)
SWEED32's Avatar
I am pretty sure your 16" rims wont clear your rotors... I think the smallest you can go is 17".... Good luck
2004 TITAN C.C. 4X4 Smoke
2.5" Daystar, 325/60R18 Nitto Tires, Helo Wheels
SWEED32 is offline   Reply With Quote
Old 08-16-2004, 09:40 AM   #4 (permalink)
Sammy Sandbag's Avatar
Sweed is right. While the bolt patern is the same, you won't clear the caliper. Even some 17" wheels don't clear the caliper, such as DTEK's first try with the Mickey Thompson Classic IIs.
-Counsel Yourself
Old 08-16-2004, 09:56 AM   #5 (permalink)
SWEED32's Avatar
Calipers, rotors... yeah you knew what I meant maybe I should stick to Motocross....
