Fix that leaking radiator - Nissan Titan Forum
post #1 of 10 (permalink) Old 05-10-2012, 07:34 AM Thread Starter
earz's Avatar
iTrader Score: 0 reviews
In January, my radiator started leaking from the usual spot at the seam between the lower end tank and the core. I limped it around town for a couple weeks because I was too broke from just replacing the transmission. I wanted to get an all aluminum rad. but couldn't afford it. I found a new plastic end tank rad. on eBay for $70 shipped. I couldn't pass it up. I installed it a few days after it arrived and the leak was gone...until last week. ::explitive::explitive::explitive:: I emailed the company from eBay, but the best they could do is ship another rad. once a tracking number showed the defective rad. was in transit. It's my only vehicle, so that was a no go. After a little research online, I found that some guys on a Porsche 928 forum were repairing/replacing the end tanks and seals. One dude even made some replacement clamps to hold the plastic tank to the core. I ran and grabbed my old radiator from the shed and decided to see if I could get the lower tank off to try to seal the old radiator back up. A small screwdriver and a small tire spoon along with some careful work to straighten the aluminum tabs without breaking them and I had the tank off. Here's some pics for those that have never seen the inside of a Titan radiator.
The tranny cooler (which I have bypassed) is a double walled tube that the tranny fluid flows through. To get the tank off, the tabs don't have to be completely straightened. You can bend them to around 60* and flex the tank enough to get it out. Once the tank is out, I used a crecent wrench to straighten them a bit more so the tank will easily slip back in place. There is a large rectangular o-ring that seals the tank. The Porsche 928 guys have a source for replacement end tank seals. I know AC Delco has many different sizes available for some GM radiators - I need to see if I can find one that fits this thing - just for future reference...
Anyway, back to the story. Since the tabs were pretty easy to straighten out, surely I could clamp them a little tighter. I grabbed a pair of channel-locks and slid under the truck. At this point the coolant drips were frequent, one about every three seconds. After I got the fan shroud loose and held up out of the way, I worked all the way across the backside of the radiator, squeezing each tab. Quite a few of the tabs crimped down considerably more than they had been. I even got the tabs on the short ends of the radiator. Once I was done, there were no more drips. HOORAY. I got the fan shroud bolted back up, topped off the coolant tank (which was empty) and went to pick the kid up from the sitters. I've only put about 30 miles on it so far, but it is staying dry. It may be worth a shot for those of you needing to get a few more miles before upgrading to an all alum. radiator.*
2005 4WD LE
K&N drop in filter • Magnaflow muffler
black painted stock wheels • bedlined mirrors
earz is offline
The Following 3 Users Say Thank You to earz For This Useful Post:
RobKar (05-24-2012), sudden urge (05-10-2012), TA CC TX (05-10-2012)
Advertisement
post #2 of 10 (permalink) Old 05-10-2012, 07:50 AM
AcidJake75's Avatar
iTrader Score: 17 reviews
Send a message via AIM to AcidJake75 Send a message via Yahoo to AcidJake75
Re: Fix that leaking radiator
I have to admit - great job.. I also understand not having enough cash... But I also understand that I dont want to do the work over and over.. Since you have a fix (no telling how long its going to last)... save up for the CSF and that way you can install once and be done with it..
04 KC Smoke Titan 4X4
PRG, Hypertech, 08 Brake Upgrade, Black Rhino 18x9 +12, 305/65/18, Bilstein 5100's, Pro4x Springs, AAL's, CSF Rad, 2Ί Advance, Debadged, GoGrounding, Radiator Bypass Cooler, AIRaid MXP Intake, Axle Vent Mod, DDM 5k Lows & 3k Fogs, Blacked out Head lights, Stillen LT, BALLER PRT PIPES (BECAUSE I DONT LIKE BUYING SHIET TWICE), JBA Exhaust, Magnaflow Glasspack, Vibrant, Tech12, Volant LED Tails..
AcidJake75 is offline
post #3 of 10 (permalink) Old 05-10-2012, 08:30 AM
TA CC TX's Avatar
Garage
iTrader Score: 5 reviews
That is a little tranny cooler? or is that to heat up the fluid LOL
[04 CC BT OFFROAD
TA CC TX is offline
post #4 of 10 (permalink) Old 05-10-2012, 09:25 AM Thread Starter
earz's Avatar
Maybe it is a "fluid heater" but the stock setup has a large cooler inline with this. Seems counter-productive to heat the fluid, then cool the fluid or vice versa.
2005 4WD LE
earz is offline
post #5 of 10 (permalink) Old 05-24-2012, 11:30 AM Thread Starter
earz's Avatar
Two weeks in with daily driving (~20-30 miles a day) and its still dry. I did order a new OEM radiator cap - in case the cap was causing too much pressure to build in the system. Here's the new cap (right) next to the original cap (left). Looks like they changed the design a bit - or was my old cap not OEM?
2005 4WD LE
earz is offline
post #6 of 10 (permalink) Old 05-24-2012, 12:41 PM
Nick568's Avatar
Your cap looks just like mine. Nissan must've changed the design at some point. Or I also have a non-OEM cap, lol.
05 KC 4x4 BT OR
BD PP, 08+ shackles, 08+ 4x4 springs w/ Bilstein HD's, Lightforce 240's, Rigid Dually spots & D2's, BAK G2 tonneau, Back Rack, and many hours of maintenance work
Nick568 is offline
post #7 of 10 (permalink) Old 06-16-2012, 07:50 PM Thread Starter
earz's Avatar
Update: a little over a month and still bone dry.
2005 4WD LE
earz is offline
post #8 of 10 (permalink) Old 06-16-2012, 08:32 PM
jdmartin's Avatar
iTrader Score: 6 reviews
Nice job and thanks for the update! It's very encouraging, should we have problems.
jdmartin is offline
post #9 of 10 (permalink) Old 01-26-2013, 09:16 PM Thread Starter
earz's Avatar
Update - its been 7 months and approx 7000 miles since the re-crimp, but this past week, it started leaking again. We have had some pretty cold temps (20°'s) here for a month or so with a few 50-60° days sprinkled here and there. I decided to try the crimp again. I pulled the skid plate and fan shroud and found two tabs towards the center that didn't look like they were crimped as well as the others. I gave 'em a squeeze with the channel locks and they crimped down a bit more. I checked the rest of the tabs but couldn't tell if the rest crimped down any more. I washed the remaining coolant off, topped off the coolant (which was only about 1 cup low) and its been dry for a couple days. I'm not sure if I just missed those two tabs, or if the temp fluctuations cause the tabs to "un-crimp", or maybe there's an "excessive coolant pressure" issue with these trucks that the crimped on end tanks cant handle since all stock radiators suffer from this problem? Who knows. I'll keep an eye on things and see how long this lasts me. It only takes me about 20 minutes start to finish...
2005 4WD LE
earz is offline
post #10 of 10 (permalink) Old 02-14-2014, 12:51 PM
kbadger3's Avatar
iTrader Score: 4 reviews
Is this still working for you ? I just started leaking on the bottom on mine in the last couple of days, I am thinking about trying this out this weekend.
2006 Titan SE
Mods: Air Box Mod(gone), AIR Raid MXP intake, DIY Grill
Audio: Kenwood DDX-514, Bluetooth & iPod hookups, custom ported box w/ 2 10W3's, Kicker 1000.1
Interior: Beltronics RX-75 radar detector, Auto-dim Mirror w/ temp & compass, Seat Heaters, Viper 5501 autostart, all LED bulbs.
Exterior: Bull bar, Dual 20" LED Light Bars, 35 Watt HID Hi & Low Beams in quad projector headlights, LED Fog lights, Smoked LED Tail Lights, Smoked LED 3rd Brake light, LED Tailgate Bar, Dynomax dual exhaust kit with vibrant ultra Q...More to come
kbadger3 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Radiator(?) Leaking, can I still drive? LD5050 Titan Problems & Dealer Service 10 05-30-2011 08:08 PM
Another 50K leaking radiator doctor steve Titan General Discussion 9 12-14-2010 08:08 PM
Radiator is leaking... loufish Titan Problems & Dealer Service 8 05-06-2008 07:21 PM
leaking radiator TruckerT-Titan Titan Problems & Dealer Service 1 05-11-2007 08:21 AM
Radiator Leaking Birdhunter Titan Problems & Dealer Service 0 10-04-2006 09:02 PM
You may post new threads
You may post replies
