Does my truck have the B-LSD? - Nissan Titan Forum
post #1 of 26 (permalink) Old 08-25-2004, 11:25 PM Thread Starter
iTrader Score: 0 reviews
I have an SE 2x4 with the Big Tow package, no off road. According to the info Nissan publishes, it appears that the brake LSD is only available on 2x4's with the off road package. But it clearly says on my window sticker that it is on my truck as part of the big tow package. The owners manual confuses things further by saying the B-LSD could be represented by an idicator light on the dash that says B-LSD or SLIP. It also says that SLIP is an indicator for traction contol, part of the VDC system. There is no place for a B-LSD light on my dash, just the SLIP light. When I stepped on it pretty good yesterday, and got a chirp from one tire, then the truck hooked up and took off. The SLIP light was blinking, but power didn't feel like it was being cut. Was that the traction control, B-LSD in action, or both?
Jason K.
Titan Power is offline
Advertisement
post #2 of 26 (permalink) Old 08-25-2004, 11:27 PM
go around a corner flooring it. If you have an LSD then you'll leave two patches of rubber. If you don't have an LSD, then you'll only leave 1 (inside tire)
Potroast is offline
post #3 of 26 (permalink) Old 08-26-2004, 02:57 AM
That's true with a conventional LSD diff, but not with the Titans. Jeez Potroast, don't they miss your expert opinions and advice over on the Toyota boards??
Jason, do you have VDC on your truck?
JetTech is offline
post #4 of 26 (permalink) Old 08-26-2004, 05:30 AM
jeez could you lose the hostility?
what the hell is the point of the Titan's LSD if it doesn't apply equal torque to each wheel?
Potroast is offline
post #5 of 26 (permalink) Old 08-26-2004, 05:38 AM
goathead's Avatar
iTrader Score: 2 reviews
the TITANS LSD uses braking to regain traction vs the mechanical posi type rear ends. if im wrong, tell me.
steve
SOLD
K&N® FIPK-LEER® 100R TOPPER-NCD® 4x4 Level Kit-
Uprev Tuned-JBA Long Tube Headers
Cajun Catted Bpipes-JBA Y-Pipe-BorlaXR-1 Muffler-Ultra Quiet Resonator
goathead is offline
post #6 of 26 (permalink) Old 08-26-2004, 05:53 AM
IMADOGMAN's Avatar
Your truck with VDC (from the online owner's manual)
VEHICLE DYNAMIC CONTROL (VDC)
SYSTEM (if so equipped)
When accelerating or driving on slippery surfaces,
the tires may spin or slide. With the Vehicle
Dynamic Control (VDC) system, sensors detect
these movements and control the braking and
engine output to help improve vehicle stability.
c When the vehicle dynamic control (VDC)
system is operating, the slip indicator in the
instrument panel blinks.
c When only the traction control system (TCS)
portion of the vehicle dynamic control system
is operating, the slip indicator will also
blink.
c If the slip indicator blinks, the road conditions
are slippery. Be sure to adjust your
speed and driving to these conditions. See
.Slip indicator light., and .Vehicle dynamic
control off indicator light. in the .Instruments
and controls. section.
c Indicator light
If malfunction occurs in the system,
the and indicator lights come
on in the instrument panel.
As long as these warning lights are on, the
traction control function is canceled.
[SIZE=2]The VDC system uses an Active Brake Limited
Slip (ABLS) system to improve vehicle traction.
[/SIZE]The ABLS system works when one of the driving
wheels is spinning on a slippery surface. The
ABLS system brakes the spinning wheel which
distributes the driving power to the other drive
wheel. If the vehicle is operated with the vehicle
dynamic control system off using the VDC OFF
switch, all VDC and ABLS functions will be
turned off.
< See note below
The ABS will still operate with the VDC
system off. If the ABLS system is activated, the
slip indicator light will blink and you may hear a
clunk noise and/or feel a pulsation in the brake
pedal. This is normal.
The part above that is in Blue is not accurate. Your paper owner's manual has new wording that changes this. Check your owner's manual for the correction.
JBA Longtube Headers
Cajun Catted B-pipes
JBA Catback exhaust with Vibrant UltraQuiet Resonator
Tuning by UpRev (Seymore4)
[COLOR=Blue]IMADOGMAN
2004 NISSAN TITAN KC SE
4x4 Offroad (E-locker)
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
IMADOGMAN is offline
post #7 of 26 (permalink) Old 08-26-2004, 06:21 AM
steve
bah, what a stupid marketing plow. That is total crap.
Potroast is offline
post #8 of 26 (permalink) Old 08-26-2004, 06:27 AM
GETSOMZ28's Avatar
In summary, the Titan does not have a limited slip rear.
Scott
GETSOMZ28 is offline
post #9 of 26 (permalink) Old 08-26-2004, 06:28 AM
IMADOGMAN's Avatar
Hey Potroast, Most of the people who have used their Active Brake Limited Slip, think that it is great. You may have read this thread:
Mud dragger
Seems that traction is not a problem...considering that it is just a marketing ploy...
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
post #10 of 26 (permalink) Old 08-26-2004, 06:32 AM
IMADOGMAN's Avatar
Limited slip differentials work by redirecting power to the wheel that has the most traction....ABLS works by redirecting power to the wheel that has the most traction.
It just does it in a different manner...
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
post #11 of 26 (permalink) Old 08-26-2004, 06:37 AM
okay just a couple things... Nissan should call it "active brake power distribution" or some other name then.
a limited slip differential is what it is -- and what nissan is doing isn't it!
I'm not saying that nissan's doesn't increase traction -- it very well might... But it's just not an LSD.
Glad I know now, becauase I seriously would have bought a titan, not been able to get 2 patches of rubber, and I'd bring it back and tell em make it work.
Potroast is offline
post #12 of 26 (permalink) Old 08-26-2004, 06:53 AM
GETSOMZ28's Avatar
Actually, even though it doesnt have a true "LSD," I still get two patches of black when I lay into it. So,whatever it does, it work similarly to a LSD.
Scott
post #13 of 26 (permalink) Old 08-26-2004, 06:55 AM
IMADOGMAN's Avatar
Oh, It will leave two patches of rubber...if that is what you need a truck for. Once the ABLS sends the torque to the opposite wheel, the brake releases and both tires will spin just fine...I promise...
If by limited slip, you mean the old style that used clutches in the differential, then you are correct. If by limited slip, you define it by what it does, (redirecting torque to the wheel with the most traction) then it is no different.
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
post #14 of 26 (permalink) Old 08-26-2004, 07:45 AM
chazz1202's Avatar
Potroast- with all those mods to your volvo why do you need to lay rubber in a titan?
chazz1202 is offline
post #15 of 26 (permalink) Old 08-26-2004, 07:54 AM
I don't need to go around laying rubber in a titan. I think everybody misunderstood me. That's not why I need a fullsize truck... And owning a Tacoma Prerunner I know the cost of tires so I have no interest in killing em any time soon. However, every now and then it's nice to leave a trail of rubber when the situation calls for such.
and although my volvo does have an LSD and can leave a nice trail of rubber, it's fwd, so it's not exactly the prettiest to see burning out. I always thought it odd to watch the front tires burning out, lol.
Potroast is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
You may post new threads
You may post replies
