Old 05-20-2007, 04:21 PM   #1 (permalink)
Slotted Rear Differntial Question
The other day when I was checking out the new Tundra's one of the salesmen knocked the Titan slotted rear differential but I'm not sure why.
My brother-in-law said the slotted rear differential helps keep it cooler and this is an advantage over the enclosed rear differntial covers.
Is this true, and if so, why wouldn't all manufacturers want to do the same thing?
thanks
gasa765 is offline   Reply With Quote
Old 05-20-2007, 04:37 PM   #2 (permalink)
Nascar Fan's Avatar
Re: Slotted Rear Differntial Question
Cost.... that is the bottom line. Yes it is there for heat disapation. It could be some rearends just don't need the extra cooling also.
2005 LE CC 4X4, Nav, Off Road, Big Tow, Sun Roof, Trac System. 2 1/4 Leveling kit, Pace Edwards Jackrabbit bed cover, Flowmaster 70 series.
Nascar Fan is offline   Reply With Quote
Old 05-20-2007, 05:05 PM   #3 (permalink)
HudsonValleyTitan's Avatar
The finned diff cover is aluminum and disapates heat much better than a solid cover.
- Joe
Old 05-20-2007, 07:44 PM   #4 (permalink)
I just read somewhere that the Titan rear end is the same size as the Nissan Frontier.
Is that true??
Thanks
Old 05-20-2007, 08:02 PM   #5 (permalink)
Is that true??
Thanks
Their both Dana 44s but they're not the same internally. I don't know about "size".
- Joe
Old 05-21-2007, 06:31 AM   #6 (permalink)
Sounds like the Tundra sales man was reading from his talking points list.
The Titan started out with a solid cover and 75-90 dino oil.Nissan found out that didn't do the job, so switched to 75-90 synthetic oil. Nissan found out that didn't do the job so switched to a finned cover and 75-140 synthetic oil.
The Titan has a ring gear that is 2" smaller and the diff holds a little over 2 quarts of oil.
Nissan had to do something to in an attempt to keep the oil/diff cooler that is why they made the changes.
The Tundra diff hold 4 quarts of oil, nearly double the capacity of the the Titan.
To answer your question as to why other manufactures don't use a finned cover, the answer is that they don't have to. They use a diff that has a larger ring gear and a larger oil capacity to match the needs of a truck.
2007 Tundra Limited DC 4X4
5.7L,NAV,TRD,TOW
Xlerator Exhaust
aFe Stage 2 CAI
Desert Sand Mica
skyhammer is offline   Reply With Quote
Old 05-21-2007, 06:52 AM   #7 (permalink)
Probably to distract you from the Tundra's broken crankshaft problems.
Old 05-21-2007, 09:19 AM   #8 (permalink)
I doubt that the sales man even knows of any problems. Of the 4 Tundra forums I belong to there has been a grand total of one cam shaft failure.
He got a new engine, Toyota made his payments while the engine is being installed and they gave him a 7 year/ $0 deductible/100k warranty.
Toyota has narrowed the problems to 40-50 engines and is sending letters to those owners so that they can arrange to get a new engine, even if theirs has not failed.
5.7L,NAV,TRD,TOW
Xlerator Exhaust
aFe Stage 2 CAI
Desert Sand Mica
Old 05-21-2007, 09:37 AM   #9 (permalink)
Originally Posted by skyhammer
....He got a new engine, Toyota made his payments while the engine is being installed and they gave him a 7 year/ $0 deductible/100k warranty.
Good business! Toyota isn't on top because of luck.
4DSZR1 is offline   Reply With Quote
Old 05-21-2007, 01:38 PM   #10 (permalink)
cneary812's Avatar
man your mind is being corrupt by the toyotas!! be careful or you may end up one of them oh no wait... you are one of them!!
oops... finned cover makes it cooler so it doesn't explode lol
05 LE Crew Cab Smoke OR 4x4
airbox mod with K&N
Scangage2/blendmount
Roadmaster Active Suspension
future mods - JBA Evol , PRG leveling kit, 2* timing advance, Injen Powerflow, and more
cneary812 is offline   Reply With Quote
Old 05-22-2007, 12:20 PM   #11 (permalink)
54warrior's Avatar
Here's my opinion on the finned cover: a bandaid fix for our tiny rear ends
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government. - Thomas Jefferson
Old 05-24-2007, 09:14 AM   #12 (permalink)
That's the 1st time that my rear end has been called tiny.
rtapia is offline   Reply With Quote
slotted, drilled, or both? AETitan Titan Wheels, Tires & Brakes 4 05-17-2007 01:33 PM
Brakes: Slotted or Not? burntfox Titan General Discussion 6 11-12-2005 08:38 PM
Cross slotted/drilled rotors Prlauren Titan Performance Modifications 18 09-16-2005 04:50 PM
Chrome slotted taillight covers PENROSE Titan Parts & Accessories 13 07-16-2005 05:54 AM
Slotted/Drilled rotors adjmcloon Titan Performance Modifications 5 07-28-2004 09:57 PM
