Easy lift tailgate mod - Nissan Titan Forum
post #1 of 16 (permalink) Old 11-14-2012, 11:15 AM Thread Starter
iTrader Score: 4 reviews
OK I have an 2010 base titan without the easy lift tail gate for my work truck, and a 2008 LE for my personal truck. I was installing my LED tail lights on the LE and saw how the easy lift worked. I pulled the right tail light on the other truck and all the parts are there exempt the shock. I ordered the shock for the other truck and it fit right on. Easy mod.
Pt number 90450-zh000 (gas stay)
$24.05 at my Nissan dealer...
Sent from my iPhone using AutoGuide.com Free App
20" Black Burst Wheels, Paranha Body Kit, Airaid CAI, PRG 2" Drop Shackles, Black Dual Halo Projector Headlights, 8K HIDs, Smoked LED Tail Lights, Smoked LED Third Break Light, All LED Interior Lighting. 1 Kinetik HC2000 Pro Battery for starting 2 Kinetik HC 2000 Blue batteries for audio. Grounding Kit, Custom Battery Connections. Megillian GPS in OEM Location, OEM Rockford Head Unit, JBL MS-8,Precision Power DEQ-8, Precision Power Phantom Amps, PPI Power Class Components for Front Stage, PPI Art Components for Rear Stage, PPI Art SQ 8 Subs, Scosche EFX wiring and Fusing. AutoPage Security With Remote Start and Remote Climate Control.Green Accent Lighting. Up Rev ,Keystone Good Hood, JBA Long Tubes, JBA Catback, and Cajun Catless B-pipes
3rd Place 2012 USAC World Finals Mod SQ
2nd Place 2012 IASCA Finals Amature IQC
1st Place 2013 IASCA Spring Break Nationals Amature ICQ
mbquart1 is offline
The Following User Says Thank You to mbquart1 For This Useful Post:
imaweirdo159 (11-14-2012)
Advertisement
post #2 of 16 (permalink) Old 11-14-2012, 11:48 AM
imaweirdo159's Avatar
iTrader Score: 0 reviews
Will this work for older models as well?
Sent from my DROID BIONIC using AutoGuide.Com Free App
2004 Titan KC XE, 4x4, Preferred Pkg, OR, PRG 2" leveling kit, Falken Rocky Mtn 285/70/R17 tires on some Ultra Thunder 17x8 wheels.
Rear Diff Grenaded 2/18/2012
NEXT: JBA LT Headers, UpRev, Airaid MXP, Cajun B Pipes
imaweirdo159 is offline
post #3 of 16 (permalink) Old 11-14-2012, 12:00 PM Thread Starter
Pull the right tail light. If the mounting ball are there I would think it would. There is one ball mounted just behind the taillight and another on a lever at the tailgate hinge. If yours has it pose the year and model for others.
mbquart1 is offline
post #4 of 16 (permalink) Old 11-14-2012, 12:21 PM
dubyam's Avatar
Re: Easy lift tailgate mod
If not, I believe you can buy the entire kit (mounts and shock) for not a whole lot more money. It's a favorite feature of the T for me. No more hassle with the tailgate.
dubyam is offline
post #5 of 16 (permalink) Old 11-14-2012, 01:10 PM
baseballfanz's Avatar
iTrader Score: 1 reviews
Not as easy as installing a gas strut but can be done. The 04 has everything on the opposite side for some reason. The 05+ everything is the same.
Titan Gas Assist Tail Gate Retro Fit 03/04
Good find mbquart1
2014 Wrangler Unlimited Sahara
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is offline
The Following User Says Thank You to baseballfanz For This Useful Post:
post #6 of 16 (permalink) Old 11-14-2012, 05:27 PM
Pictures would be cool... I have a base model 2011 and have never seen how the easy lift works.
kaipo13 is offline
post #7 of 16 (permalink) Old 11-14-2012, 05:31 PM
Look like this (this is the 04 modified but should be similar)
Sent from my 2005 Red Alert Titan via the Autoguide app on my ASUS Transformer.
post #8 of 16 (permalink) Old 11-14-2012, 05:34 PM
iTrader Score: 5 reviews
Is there anything you don't know or have a pic of?
2010 Titan SE 2WD
Current Mods
-JVC DVD/NAV, JL Audio Components JX 1000 amp running 2 12" 12W3, JX 360 amp, Backup cam
-22x12 -44 offset Hammered Hostiles, Toyo Open Country MT's 35's -Airraid CAI-RC ,Spindle Lift 7.5 front 4 in the back - Icons up front-Volant Tail Lights, custom gauge plate with leds, Front and Rear Swaybar, chrome grill billet, black modded head lights, 5125's in back, uprev, Bushwacker fenders-JBA LT, Catted Cajuns bpipes, and MBRP Catback
murf51 is offline
post #9 of 16 (permalink) Old 11-14-2012, 06:58 PM Thread Starter
That was like mine. It was no worse that changing a brake light bulb. It didn't take 5 mins. Did it on the dealers lot before I left. Only takes a phillips screwdriver or a 10mm wrench or socked to pull the taillight housing...
mbquart1 is offline
post #10 of 16 (permalink) Old 11-15-2012, 07:43 AM
thad5515's Avatar
Um yeah, my penis.
Hey bball, check your inbox.........
PA Chapter
07 Crew Radiant Silver, 2" PRG leveling kit, InSys USA CAI, 22"Magna Flow dual in/dual out, axle vent mod, fog light mod, 50% front tint
LED turn/brake/3rd brake lights, Recon Line of Fire tailgate bar, MaxGuard Spray in bed liner, Tonneau Masters Slant-Side cover
Falco Engine Bay Light Mod Kit, Gimmie Light Bed Kit
.45 Reasons to try to car jack someone else!!
Not as much as some....but I'm working on it.
thad5515 is offline
post #11 of 16 (permalink) Old 11-15-2012, 07:54 AM
spoolie's Avatar
The strut is 11.00 at advance auto parts.
2009 XE Silver....2.5" SS full exhaust.....Dual Flowmasters with dual 18" resonators....Airaid....Detroit TT....bakflip G2....20" American Eagle wheels....2" level kit....HD trans cooler.. JBA full length headers, Cajun 2.5 catless mid pipes, tuned on Uprev.
Retro'ed Acura TSX lens in factory housings along with full Memphis audio M class system.
spoolie is offline
The Following User Says Thank You to spoolie For This Useful Post:
baseballfanz (11-15-2012)
post #12 of 16 (permalink) Old 11-15-2012, 08:47 AM
Cool, I need to replace mine.
Originally Posted by thad5515 View Post
Um yeah, my penis.
No I don't want you to pm me a picture of your penis.
post #13 of 16 (permalink) Old 11-15-2012, 10:52 AM
Do you have a part # for Advance Auto? Went there and everything they had was $25 or more. Maybe they're looking up the wrong part.
post #14 of 16 (permalink) Old 11-15-2012, 10:55 AM
spoolie's Avatar
Same problem...I went to the local store and had them search deeper. Internet site had special order strut for 20+, store had it in stock for 11 or 13 dollars. It's called something different than what you'd think. I'll see if I can find the sleeve it came in.
spoolie is offline
post #15 of 16 (permalink) Old 11-15-2012, 04:25 PM Thread Starter
It's called a gas stay. I went thru them at advanced for about an hour and gave up and went to Nissan and got mine.
Advance was only able to look up the ones for the hood( I guess that was what they for didn't really say).
mbquart1 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
fabricated my own mini lift. easy and affordable ducky1980 Titan Performance Modifications 9 07-19-2010 12:45 PM
Rancho easy lift and daystar spacers ljpviper Buy/Sell 1 06-03-2010 10:15 AM
Easy Lift tailgate assist Bulldog Titan Parts & Accessories 26 11-07-2007 11:47 AM
For 2004 Titan owners, tailgate lift assist? stratplaya Titan General Discussion 28 04-22-2006 11:01 PM
How easy it is..... SHIPREC13 Titan General Discussion 3 10-03-2005 08:57 PM
You may post new threads
You may post replies
