Help: Titan is having a bad day. - Nissan Titan Forum
Old 11-18-2012, 02:26 PM   #1 (permalink)
iTrader Score: 0 reviews
Its been a rough day for my T.
First: Came home from a trip; went to start the T and got the slow crank. Dead battery. Replaced it.
Second: After just a bit of driving she through a code. P1148 & P1276. After coming on here, I replaced the upper driver side oxygen sensor with a new Bosch unit. Continued to drive it and the check engine light is still on. Stopped in at Autozone to have them run the codes and same deal. Guy tells me I might have to drive it 120 miles to reset. No idea if this is going to fix itself or not. He mentioned it possibly being the EGR unit??? Anyone have any thoughts?
Lastly: This is the icing on the cake for me. Backing out of autozone... I see a truck... avoid it no problem and ~bang~. Smack a cement light pole (I know... smack me). Damage... pushed the tin foil bumper up well enough to crumple the corner of my truck bed. This is where I need your opinions. Replace the left side of the truck bed? Have someone pull it out? I checked online... our truck beds are not readily available. A new OEM unit left side only is going for $750.
Appreciate any and all advice.
Basics: Bilstein 5100's | 08+ Shackles | 08 Pro 4x springs | 08+ Diff Cover | 1.5" PRG Blocks | Duratracs | Magnaflow
senecak19 is offline   Reply With Quote
Advertisement
Old 11-18-2012, 02:37 PM   #2 (permalink)
baseballfanz's Avatar
iTrader Score: 1 reviews
Re: Help: Titan is having a bad day.
You can try the ECU reset procedure to clear up the code right away or if it was indeed the O2 sensor you do need to drive a bit to see if it clear.
As for the bed, post a picture. Lets see how bad it is.
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
Old 11-18-2012, 02:43 PM   #3 (permalink)
Here you go:
I'm mad at myself, but it couldn't have been a more perfect wreck. My bumper already had a dent from when I bought it and the only rust spot was on that corner.
Old 11-18-2012, 02:54 PM   #4 (permalink)
jtrick's Avatar
iTrader Score: 5 reviews
Ouch! Sorry about the bad day man. That sucks.
2008 Crew Cab 2WD
2.5" Front, 1.5" Rear Lift
Billstein 5100's on Middle Perch
PRG Extended Endlinks
2" Wheel Adapters
BDGT Tuned with RAM Mount
Airraid MXP CAI
Flowmaster Exhaust
275/70R/18 Nitto Terra Grapplers
Bedlined Everything
Legit 8k High and Low HIDS
Legit Blue interior LED package
20% Tinted Front Windows
jtrick is offline   Reply With Quote
Old 11-18-2012, 05:04 PM   #5 (permalink)
Firestingwisher's Avatar
Send a message via AIM to Firestingwisher
I would say just have it pulled out...
2007 Titan, King Cab XE
Radiant Silver
Electric cable door locks & Valet keyless Entry, Anzo Halo projectors, Alpine INA-W900 BT, Diamond Hex 4 channel 520w amp, Rockford Fosgate TB1500 mono block, 2x 12" Infinity Reference subs, Focal K2 Power 165krX3, Viair 480c onboard air system with 2 gal tank, 2 Grover 1510 Stuttertone Airhorns
24" #4 Crave Alloy wheels, 305x40xr24 General Grabber tires, K&N Lifetime Airfilter, 2 True Dual (1 in, 1 out) Flowmaster 40 series mufflers... More to come
Firestingwisher is offline   Reply With Quote
Old 11-18-2012, 05:30 PM   #6 (permalink)
I'll take your word for it. I'm no body guy, but I assume this "has potential" to be pulled? To me... it probably looks worse then it really is. As for the bumper... screw these things. I think I'm going to make my own.
Old 11-18-2012, 07:15 PM   #7 (permalink)
I've seen worst been pulled and it came out really good. Depends on the shop/people doing it. Go get an estimate for both, pulling and replacing.
What about insurance?
Sent from my 2005 Red Alert Titan via the Autoguide app on my ASUS Transformer.
Old 11-19-2012, 08:18 AM   #8 (permalink)
I was hoping to avoid going through insurance. I have a friend of mine that can source aftermarket parts at cost and he does bodywork. I'm hoping he can fix this for under $1000. I just assume pay him instead of paying my insurance company (over the next decade). My guess is, there are no aftermarket panels for this yet. I appreciate all the the advice. Fortunately, the truck is still drive-able. Now I just need to find this ECU reset procedure and see if the O2 sensor I replaced is the culprit.
Old 11-19-2012, 08:36 AM   #9 (permalink)
Nick568's Avatar
Replacing it is not going to be as easy as you're likely thinking. The bedsides are welded to the box part of the bed with a bunch of spot welds. To replace the bedside, you will have to drill out the welds, grind them down, them re-weld the new bedside back on. Then not to mention paint, etc...
I think pulling it will likely be your best option if it can be pulled back into shape.
Also, try a ECU reset for your code problem as baseballfanz suggested.
05 KC 4x4 BT OR
BD PP, 08+ shackles, 08+ 4x4 springs w/ Bilstein HD's, Lightforce 240's, BAK G2 tonneau, Back Rack, and many hours of maintenance work
Nick568 is offline   Reply With Quote
Old 11-19-2012, 05:17 PM   #10 (permalink)
Thanks everyone for the support.
I stopped into today to talk to my friend at the body shop. He showed me the machine needed to pull the bed back into shape. Looks like I should be able to get it close and then some straight forward bondo and paint and she should be fine.
Anyone know where I can source the decal in the back and or the "TITAN" letter s that are on the back of the tailgate???
Current plan is to redo the rear quarter of the truck and the tailgate. The tailgate had some dents when I bought it. This gives me a chance to fix it and blend the paint into the rear quarter reducing the potential visibility of any discoloration.
Advertisement
SEO by vBSEO 3.3.2
