Re: Spindle/UCA spacer?
Messing with added stress to the ball joints just screams ball joint failure. You could just add a little bit of positive camber to the uca adjustment so it won't have cbc. a small amount of positive camber isn't going to hurt anything. if you think about it your wheels are changing camber all the time while you are driving, its incorrect tow that will kill your tires. You must have those uca's cranked if there making cbc. lol those dirt king uca's have a crazy amount of added clearance.
2006 Radiant Silver 4x4 CC LE
Performance: 2011 Stock Exhaust and K&N Drop In Filter
Suspension: NCD 2" Leveling kit and PRG cam bolts
Wheels: Fuel Boost 18x9" with 20mm offset wrapped with 275/70-18 Toyo Open Country AT2's
Misc: Full Interior/Exterior LED's Plus Super Reverse 2.0 Lights From LegitLED'S, TonnoPro TriFold Tonneau Cover
