sway bar flipped, End links destroyed. - Page 2 - Nissan Titan Forum
Old 12-08-2012, 07:59 PM   #16 (permalink)
robstrevor's Avatar
iTrader Score: 1 reviews
PIC!!! Now my sway bar flips from pulling out of the driveway with those bent links. Lol
Sent from my HTC Sensation 4G using AutoGuide.Com Free App
robstrevor is online now   Reply With Quote
Advertisement
Old 12-09-2012, 12:15 PM   #17 (permalink)
robstrevor's Avatar
Anyone try making their own end links? Thinking about doing it maybe with some pins for a quick disconnect. Anyone know how long stock end links are? I'd measure if I wasn't working.
Old 12-09-2012, 12:44 PM   #18 (permalink)
Jayk's Avatar
iTrader Score: 0 reviews
Re: sway bar flipped, End links destroyed.
Originally Posted by robstrevor View Post
Yes, that is why. I was trying to flip it back up bit that wasn't gonna happen very easy do I gave up and left it.
If it flips again: Grab your jack, take the weight off, and flip it back. It only takes a couple minutes, and then you won't be grinding your endlinks on your wheels when you make turns.
Bad Company
'07 4X4 CC SE: BDGT-Performance Tuned/Removed WOT Restriction/2* Advance/Airaid MXP CAI
Bilstein 5100s on middle setting/PRG 2" Spacers/PRG 1.5" Rear Blocks/Dirt King UCAs/PRG Camber bolts/ PRG Endlinks
Toyo Open Country MT 33x12.5x18s/-06 Raceline Raptors/PWM
AVS In-Channel Window Flares/No-Name Bug Shield
Truck Champ Nerf Bars/30% Window Tint
~In the Works: Metal Mulisha Exhaust/Headlights~
Jayk is offline   Reply With Quote
Old 12-09-2012, 02:25 PM   #19 (permalink)
robstrevor's Avatar
I'm just gonna disconnect it till I can make some end links, or try anyway.
Old 12-09-2012, 08:02 PM   #20 (permalink)
HRTKD's Avatar
iTrader Score: 2 reviews
With the end links bent like that I doubt that it would stay upright for long if you managed to put it back.
With regard to quick disconnects I don't see that working well. There isn't any place (good) to move the sway bar to. I think if you rotated it so that the bolt holes were towards the front then it would stick down too far. Securing it so that it didn't rattle or cause damage would be challenging. Plus part of the end link would still be there and flopping around. Then again, maybe I don't see what you're seeing.
«ClearBra, Leer 100XQ, MM SI9500 Winch, 18" Magnaflow, Berk b-pipes, Volant PowerCore, AMSoil bumper to bumper, Uprev tuned»
«SAW Coilovers and rear shocks, PRG upper control arms and shackles, Hellwig rear sway bar»
Jim
Old 12-09-2012, 09:39 PM   #21 (permalink)
NorCal 4x4's Avatar
iTrader Score: 4 reviews
You just need to turn the sway bar all the way forward and zip tie it, (heavy duty long one like you find at Lowes or Home Depot), to the round bumper supports. I've done it for or week or two with my DRe's and again when I had my backup set of Bilsteins on. When I did it, my endlinks were removed, but they could be secured with zip ties easily enough.
I was going to do it today, (to try sans bar with my Radflos), but the Christmas lights took longer than I was planning. I'm considering doing the quick disconnect I posted the link to on the previous page, to Greg's endlinks, because at least with the DRe and the Bilsteins I prefered the on road cornering with the bar on.
Old 12-09-2012, 10:03 PM   #22 (permalink)
honda250xtitan's Avatar
iTrader Score: 6 reviews
I considered making my own extended end links. then summer ran out and i came to chicago for school. just cut and add in an inch or so. hopefully the heat from welding doesnt fry your ball joints.
2011 White CC pro4x
Flowmaster Y
Banks Muffler
Airaid MXP 4" Intake
PRG UCA's
Extended travel Sway-Away 2.5 coilovers
PRG Camber Bolts
Homemade Traction Bars
Fuel Boost 18x9
Nitto Terra Grapplers 295/70 18
Front BORA 1.25 Wheel Adapters/ Pinch Weld Mod
6K HID's
10" Sub/Kenwood Amp
Gone Forever: 06 KingCab 4x4
6" ProComp, Bilsteins 5100's, 08 4x4 coils, PRG UCA's, Banks CatBack, Nismo Cai, Superchips Cortex, Custom Bumper, 35's on 18's
honda250xtitan is online now   Reply With Quote
Old 12-10-2012, 12:16 AM   #23 (permalink)
salstats's Avatar
iTrader Score: 10 reviews
No sir the PRG endlinks will not fix the problem. I have a 4 inch spindle lift with PRG endlinks and when i turn shark my sway bar flips and dents my new PRG links. They look like sh*t now all dented. I made them long and they have not flipped but my turning now suffers cause they hit the links :sly:
Sent from my LG-MS840 using AutoGuide.Com Free App
2008 SE 2WD: Maxtrac 4" Spindle Lift with 2" Block, PRG UCA, PRG Shackles. Nitto Trail Grapplers 35x-12.5-17 Tires. PRO COMP ALLOYS SERIES 6005 rims. AirAid MXP CAI, Custom 3" Banks Catback Exhaust dumped, BullyDogGT Window Roll up Mod,
salstats is offline   Reply With Quote
Old 12-10-2012, 03:49 AM   #24 (permalink)
1AGregg's Avatar
What great info as well as a working link for the item described. Thanks SoCal
Signature Image Violation
1AGregg is offline   Reply With Quote
Old 12-10-2012, 02:12 PM   #25 (permalink)
*SocalTitan*'s Avatar
iTrader Score: 3 reviews
No prob
*SOCAL~TITAN*
2010 CC 2WD SE, 20" RBP 94R Wheels, 33X12.50R20 Toyo OC MTs, CST 4" Spindles, ICON Dynamics Coilovers (F), Bilstein 5125's (R), CST 3" rear tapered blocks, CST CBDB, MetalWorx Traction bars, 1.25" Bora Bullet Proof wheel adapters rear, PRG endlinks, PWM, Bushwacker Pocket style flares, 4" AirAid MXP CAI, RC-1 Grille w/ custom made Monster emblem, Custom Monster Energy Bezel Kit, Dual in/out Spin Tech exhaust, NFAB Nerf Bars, Spray-in Bedliner, Full LED bulb Swap interior/ exterior, Black Spyder CCFL, Projector headlights, 5000K HID Lows and Fogs, LED Tails and 3rd brake light, Weather Tech Digital fit floor liners (front), Superchips Cortex programmer, 1800 Watt Kenwood Amp, 2 12" Kenwood Excelon subs.
*SocalTitan* is offline   Reply With Quote
Old 12-10-2012, 02:33 PM   #26 (permalink)
SirDukeDH's Avatar
Originally Posted by JB View Post
Likewise ........ I'm still trying to give my sway bar away for free
I'll take your bar off your hands, i'm rolling stock and am mostly a street whore. with some very mild off road spikes......
04 XE. Motto Metal 909's 18's,Airaid MXP CAI, Banks Monster muffler, Leaf spring helper mod, green LED lights in grill and fog lights, green interior lights(under construction), Ferreus Custom Skull grill, 35% Tint, Trifecta tonneau cover, Azetta Tails, bedlined rear bumper, air ram mod, armada air dam, Eye Lid mod, Airaid TSB, Screen delete mod, Axle Vent mod
SirDukeDH is online now   Reply With Quote
Old 12-12-2012, 11:52 AM   #27 (permalink)
robstrevor's Avatar
Made my own end links with 1/2" ball joints and clevis pins as quick disconnects.
sway bar flipped, End links destroyed.-uploadfromtaptalk1355341901544.jpg   sway bar flipped, End links destroyed.-uploadfromtaptalk1355341920810.jpg   sway bar flipped, End links destroyed.-uploadfromtaptalk1355341938100.jpg
The Following 4 Users Say Thank You to robstrevor For This Useful Post:
cjoh101 (12-12-2012), HRTKD (12-12-2012), Jayk (12-17-2012), Mack207 (12-12-2012)
Advertisement
sway bar end links jay2904 Titan Suspension 2 02-10-2012 09:28 PM
Sway bar links m1186 Titan Suspension 2 12-06-2010 03:46 PM
need sway bar end links nytitan1 Titan Suspension 10 08-24-2009 06:06 PM
In need of sway bar links!!! Titster Titan Suspension 1 07-02-2008 07:48 PM
sway bar end links TITANS04 Titan Suspension 1 04-28-2008 05:41 PM
SEO by vBSEO 3.3.2
