Camper cap wiring help..... - Nissan Titan Forum
Old 12-09-2012, 05:29 PM   #1 (permalink)
iTrader Score: 5 reviews
Just picked up an A.R.E. camper shell for the titan. Anyone know of or have a wiring diagram? I have a black and red wire going to the interior light and the same going to the third brake light. I would like to somehow make a plug and tie it into the tailights so it is easy to unplug when i remove it. Any suggestions are very appreciated. I can do all the connections, but am not electrically inclined to figure out with a voltmeter, etc. Thanks very much in advance.
shawn474 is offline   Reply With Quote
Advertisement
Old 12-09-2012, 07:23 PM   #2 (permalink)
baseballfanz's Avatar
iTrader Score: 1 reviews
Get a copy of the service manual here, it has diagrams and almost everything.
http://www.nicoclub.com/FSM/titan/
I
As for connection, just go to Autozone or similar and they sell quick disconnect plugs.
Sent from my 2005 Red Alert Titan via the Autoguide app on my ASUS Transformer.
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
baseballfanz is online now   Reply With Quote
Old 12-10-2012, 05:54 AM   #3 (permalink)
Re: Camper cap wiring help.....
baseballfanz,
Thanks for the link. I found the lighting section and the stop lamp pages (pgs. 98-104). Unfortunately, this is like reading chinese. The cap I have has an interior dome light with a switch and the third brake light. My questions would be, should I tie into the trucks third brake light wiring to operate the third brake light on the cap? Or just tie into the tialight wiring? And what would I tie into to use the interior light? Would it be a 12Volt power wire? I am foreign to this kind of stuff so please bear with my ignorance.
Thanks again,
Shawn
Old 12-10-2012, 05:57 AM   #4 (permalink)
Carbeaux's Avatar
iTrader Score: 12 reviews
Does your truck have the 12v bed outlet? If it does, it'd be really easy to tap that one for the dome light and tap the brake light at the left rear for the 3rd brake light. They'd both be at about the same spot.
Hook 'Em Horns!
AKA TroubleWhore™AKA HitAndMissWhore™AKA RockyWhore™AKA SigPicNaziWhore™
ΜΟΛΩΝ ΛΑΒΕ
The Following User Says Thank You to Carbeaux For This Useful Post:
baseballfanz (12-10-2012)
Old 12-10-2012, 07:57 AM   #5 (permalink)
Yes it does have the 12v outlet. Didnt think about that; this might be easier than i thought! Thanks
Old 12-10-2012, 08:00 AM   #6 (permalink)
Carbeaux's Avatar
Just put a male plug on the end of your dome wiring and plug it in. That way you wouldn't compromise the integrity of that wiring and would still have a quick disconnect type function to it.
Hook 'Em Horns!
ΜΟΛΩΝ ΛΑΒΕ
shawn474 (12-10-2012)
Old 12-10-2012, 08:14 AM   #7 (permalink)
mjw357's Avatar
iTrader Score: 4 reviews
You'll want to tap the red/black wire at one of the tail lights for the brake. The 12v bed outlet is only hot while the truck is on, although that's an easy mod to fix.
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
The Following User Says Thank You to mjw357 For This Useful Post:
Old 12-10-2012, 08:25 AM   #8 (permalink)
There was a thread about this a while back. Some peoples' bed outlet only work with ign on, while others are always HOT. Mine is always HOT.
The Following User Says Thank You to baseballfanz For This Useful Post:
Carbeaux (12-10-2012)
Old 12-10-2012, 08:27 AM   #9 (permalink)
Carbeaux's Avatar
Mine is as well.
Hook 'Em Horns!
ΜΟΛΩΝ ΛΑΒΕ
Old 12-10-2012, 08:58 AM   #10 (permalink)
Originally Posted by shawn474 View Post
baseballfanz,
Thanks again,
Shawn
For the 3rd brake light use something like this, you can pick them up at any auto parts store.
One side go to the tail lights wires and the other go to the wire for your camper 3rd brake light.
On your tail light tap the RED from connector to Red/Black wire and the Black to Black. (See diagram).
For your dome light, if your bed outlet is not HOT all the time, the next closest would probably be the trailer harness.
Advertisement
Looking to buy a camper-what do I need for the T cbblack007 Titan Towing & Hauling 9 11-10-2011 12:46 PM
Cab over camper? triplethreat Titan Towing & Hauling 22 08-08-2011 10:51 AM
Help with camper shell wiring. #1BroncosMan Electrical & Wiring 1 07-03-2011 07:19 AM
my camper go hit BuckyBadger Off-Topic Discussion 1 01-07-2008 07:21 PM
WTB - Camper top for 6.5' KC bed yucaton_tom Buy/Sell 0 01-09-2005 07:20 AM
SEO by vBSEO 3.3.2
