1/4" wheel spacers - Nissan Titan Forum
Old 12-09-2012, 09:56 PM   #1 (permalink)
rdnjg35's Avatar
iTrader Score: 2 reviews
1/4" wheel spacers
Ok so about 3 weeks ago I got some new rims and tires from Craigslist. Input them on and they rubbed the brake caliper. I ended up buying some 1/4" spacers from the auto zone. So far they have been holding up fine I just am a little uneasy about them. Has anybody ran these and what is your experience with them. I just want to make sure they won't make my wheel fall off down the highway lol.
Ive read that some guys ground down their calipers to help them fit. How hard is that and would that be better than the spacers?
Thanks in advance as always y'all's input in much appreciated.
Sent from my iPhone using AutoGuide.com App
4" maxtrac spindles, 3" spacer, rough country ucas, 4" tapered rear block, procomp shocks
stock rims and tires(for now)
rdnjg35 is offline   Reply With Quote
Advertisement
Old 12-10-2012, 02:20 AM   #2 (permalink)
*SocalTitan*'s Avatar
iTrader Score: 3 reviews
Re: 1/4" wheel spacers
I've heard bad things about wheels "Spacers", I have no experience with them myself but if I had to run them I would retorque on a monthly basis and probably still be worried.
On the other hand have you considered wheel "Adapters" much safer alternative only thing is, is the minimum thickness you can run on a Titan without swapping lug studs is 1.25".
Check this thread out...
Bora Bulletproof Offroad Adapters! Lifetime Warranty. Awesome product!
I run wheel adapters on my rear wheels and use to run them on all 4 and never a single issue, they are always still at the same torque as I left them whenever I rotate my tires or mess with any other part of the suspension requiring me to remove the wheels.
*SOCAL~TITAN*
2010 CC 2WD SE, 20" RBP 94R Wheels, 33X12.50R20 Toyo OC MTs, CST 4" Spindles, ICON Dynamics Coilovers (F), Bilstein 5125's (R), CST 3" rear tapered blocks, CST CBDB, MetalWorx Traction bars, 1.25" Bora Bullet Proof wheel adapters rear, PRG endlinks, PWM, Bushwacker Pocket style flares, 4" AirAid MXP CAI, RC-1 Grille w/ custom made Monster emblem, Custom Monster Energy Bezel Kit, Dual in/out Spin Tech exhaust, NFAB Nerf Bars, Spray-in Bedliner, Full LED bulb Swap interior/ exterior, Black Spyder CCFL, Projector headlights, 5000K HID Lows and Fogs, LED Tails and 3rd brake light, Weather Tech Digital fit floor liners (front), Superchips Cortex programmer, 1800 Watt Kenwood Amp, 2 12" Kenwood Excelon subs.
*SocalTitan* is offline   Reply With Quote
Old 12-10-2012, 03:40 AM   #3 (permalink)
1AGregg's Avatar
iTrader Score: 0 reviews
That link seems to be broken....have any other info for this fellow and these items?
Signature Image Violation
1AGregg is offline   Reply With Quote
Old 12-10-2012, 04:01 AM   #4 (permalink)
TURNandBurn's Avatar
Send a message via Yahoo to TURNandBurn
what size rims did u get? what year is your truck? why would u want to grind down a component that helps your truck STOP!? spacers as in little thin plates with lots of holes in em for universal fit...??....yeh,ever watched your wheel go flying down the road as youre driving? spacers have been known to detonate or shatter, thats why ppl are using adapters now and as SoCal has already stated the smallest size is gunna be a 1.25" adapter.
dont tell me u got these...???... if soo, no no no no no no no no no no no!!!NO! it even says DO NOT use for offroad vehicles on the package..lol.
Search: spacer | Disc Brake Wheel Spacer | AutoZone.com
heres a link for bora's
Wheel Adapters, Wheel Spacers, Hub Centric Rings | Motorsport Tech
2008 BLIZZARD CC LE LWB
Flow Monster X pipe/Dual DynomAX bullets dumped w/ DC Sports 4" resonated exhaust tips..!!
PRO COMP 2'' POLY LEVEL KIT..PINCH WELD MOD
8K Xentec HID LOWS/FOGS
CST 4'' LIFT SPINDLES/BIlstein 5125 rear shocks
35" Nitto Trail Grapps
Maxtrac 3" rear blocks
Saw 2.5 Race Runner Coilovers
TURNandBurn is offline   Reply With Quote
Old 12-10-2012, 06:38 AM   #5 (permalink)
madrock's Avatar
iTrader Score: 26 reviews
I tried them on my old Titan. They say you need at least 5-7 turns of the lug nut for it to be "secure." I barely got 3 turns. I took them off immediately.
2008 Nissan Titan XE Crew Cab with Popular Package
PERFORMANCE: BullyDog PP | Airaid MXP 4" Missile Intake | Stillen High Flow B-Pipes | Flowmaster True Dual Super 40 | Tru Cool 4588 Transcooler
SUSPENSION: 08+ 4x4 Coils | Bilstein 5100 Struts| 1.5" PRG Blocks | Bilstein 5125 Shocks
GOODIES: HID Low Beam and Fog Lights | 4 Kragen HID's on Defiant Light Bar | Window Screen Mod | Axle Vent Mod | Custom Traction Bars | OnFair Headrest Monitors | TonnoPro TriFold Tonneau | Fumoto Drain Valve | Hankook Dynapro ATM 275/60/20 | 20x9 Ballistic Jesters
OTHER RIDE: 2007 Jeep Commander Sport 4x4 | 4 Rigid Duallys | Custom Light bar | Plasti Dipped Wheels | Hankook Dynapro ATM 245/70/17
madrock is offline   Reply With Quote
Old 12-10-2012, 06:42 AM   #6 (permalink)
rdnjg35's Avatar
Ya I've read different opinions on the spacers some say its ok some so don't do it. I check the lug nuts weekly and they all seem fine.
Turnabdburn
I've read that a lot of ppl trim down their caliper where it was rubbing. That's why I asked how good of an idea that is. And yes those are the spacers I had to get from autozone. And my wheels are 20". Not sure the width tires are 325/65r20
The only problem I would have with the wheel adapters is they my tires already rub.
Old 12-10-2012, 09:58 AM   #7 (permalink)
The link I posted is for the thread on the Bora's just so you can see pics and all the good reviews as well as all the links i the 1st post, the link TURNandBurn posted is the actual site though and that's where I ordered mine, I did a lot of research before buying and Bora BulletProof has the best product for a great price.
If all you need to shave down on the caliper is 1/8" - 1/4" you should be fine, I've seen several guys even with 2012 Titans shave up to 1/4" with no problems, that being said I personally would not do it to my Titan.
*SOCAL~TITAN*
Old 12-10-2012, 10:35 AM   #8 (permalink)
rdnjg35's Avatar
Well ill probably run these spacers until I get my spindle lift then ill run the bora adapters. Do you know if that 50 price is for one or a pair
Old 12-10-2012, 02:06 PM   #9 (permalink)
That's the price for each (1) individual adapter.
*SOCAL~TITAN*
Old 12-10-2012, 02:44 PM   #10 (permalink)
rdnjg35's Avatar
Ok. Cool. That's a pretty good price. SoCal you have these? How do you like them?
Old 12-10-2012, 03:29 PM   #11 (permalink)
I love them!!! No regrets at all, I'd buy them again any day. Install is easy, lifetime warranty, product made in the U.S. I recommend these to everyone
*SOCAL~TITAN*
Old 12-10-2012, 06:30 PM   #12 (permalink)
rdnjg35's Avatar
Thanks SoCal for all the info. I'm deffinately going to have to look Into these when I put my lift on. You got a pic of your stance?
Old 12-10-2012, 08:15 PM   #13 (permalink)
Here's a pic before the spindle lift with the 1.25" adapters on all 4 wheels.
1/4" wheel spacers-sam_0257-copy.jpg
*SOCAL~TITAN*
Old 12-11-2012, 10:17 AM   #14 (permalink)
rdnjg35's Avatar
Thanks man. That's a sweet set up. Deffinately will be getting them when I put my spindles on. Hopefully after Christmas I will have them and the spindles
Old 12-11-2012, 01:54 PM   #15 (permalink)
Good man, hope everything goes as planned.
*SOCAL~TITAN*
Advertisement
TRADE? Wheel Spacers (2") and Pro-Comp Lift Spacers 06TitanJason Buy/Sell 8 11-12-2012 04:23 AM
S> 2" Wheel spacers. Biffle320 Buy/Sell 12 12-22-2011 06:10 PM
FS 1.25" Wheel Spacers RollinPresidential Buy/Sell 11 07-05-2010 02:03 PM
1 1/2" wheel spacers maxima619 Buy/Sell 4 05-27-2010 06:35 PM
FS: 0.25" Wheel Spacers madrock Buy/Sell 5 04-05-2010 10:07 AM
SEO by vBSEO 3.3.2
