Old 09-16-2004, 08:27 PM   #1 (permalink)
gedunk's Avatar
Yet Another Problem......"VDC OFF" and "SLIP" Lights on for no reason
Barely 2 weeks into ownership and I've got yet another issue that cropped up today. I'm driving along at about 60mph and, for no apparent reason, the "VDC OFF" and "SLIP" lights came on and have stayed on no matter what I do. I did a search on the forums and couldn't find much on the subject and was wandering if this has been a common issue you guys have experienced. I'm scheduled to get my other stuff taken care of in the morning and I'll just add this to the list.
'08 Blizzard TITAN LE Crew Cab LWB 4x2
Big Tow
XM SAT
Floor Mats
Window Tint
Factory Splash Guards
Sliding Toolbox
OEM Hood Protector
20" MB Wheels Gunner 6
20" Pirelli Scorpion ATR 275/55/20
***Previous - '04 TITAN LE KC 4x2***
gedunk is offline   Reply With Quote
Old 09-17-2004, 03:00 PM   #2 (permalink)
homer's Avatar
I also had this problem (my only problem, actually), and it occured within my first two weeks of ownership as well. I don't think anyone else has posted this as an issue so it isn't a common problem. In my case the "BRAKE" light also stayed on. A faulty front pressure sensor was the culprit, the part had to be backordered and it took a couple of weeks. How'd you make out at the stealer?
2004 Crew Cab LE 4WD
Deep Water Blue, Graphite/Titanium
Born 02/16/04
Big Tow, Off Road, Bed Extender, Floor Mats, Splashguards, Bed Mat,
OEM Hood Protector, Putco Stainless Steel Bed Rails
homer is offline   Reply With Quote
Old 09-17-2004, 09:30 PM   #3 (permalink)
gedunk's Avatar
Problem solved. I've got another thread going about my alignment issues and on the 2nd attempt to fix my pull to the right, they managed to not center my steering wheel. (In other words, it was pointing to 11 o'clock) According to my service advisor, I must have turned the wheel during a sharp curve (which I had done) and with it being off center it made the computer think I had an oversteer and made the lights come on. He agreed that it should have reset itself but could not explain why it didn't. Nonetheless, they were able to reset it and it's stayed off so far. Let's hope that's all it is.
Big Tow
XM SAT
Floor Mats
Window Tint
Sliding Toolbox
OEM Hood Protector
