Old 09-25-2004, 05:03 PM   #1 (permalink)
air pressure
i checked my tires pressure they were high in pressure, the sticker on the door calls for 35psi for the p28570r17 front and rear ,put 35 in both tires the front looked noticeable low ,the tires were cold when i done all this, what are you all running in your tires?
mitch is offline   Reply With Quote
Old 09-25-2004, 05:27 PM   #2 (permalink)
NorCal 4x4's Avatar
Go with the Max. psi on the tire's side wall for best gas mileage. This is the "cold" inflation pressure.
Old 09-25-2004, 06:17 PM   #3 (permalink)
goathead's Avatar
use 35 psi. its what is recommended by the tire manufacturer based on vehicle weight. i personally would never put the max pressure that is on the sidewall. your tires will get hot w/ driving and subsequently the pressure will go up.
steve
steve
Old 09-25-2004, 06:24 PM   #4 (permalink)
IMADOGMAN's Avatar
Yeah, go with the max...let us know if you have all of the fillings in your teeth in a week or so....Otherwise 35 psi is good. You make the call.
IMADOGMAN
2004 NISSAN TITAN KC SE
4x4 Offroad (E-locker)
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
Old 09-25-2004, 06:27 PM   #5 (permalink)
NorCal 4x4's Avatar
steve
Hi Steve, 35 psi is the max pressure on the sidewall. [Edit] BTW, the sidewall is "cold inflation". [end of Edit]. [mitch mentions the p28570r17 which is the BFG Off-Roads].
Steve
