The bench is the same way-no support under legs.
This is odd,but maybe not,since they must have used the same "human specs" to work out the ergonomics of the front seat(must be a funny shaped human).The bench seat has the same problem.The front of the seat seems to tilt downward so you almost feel like you are sliding forward.Worse,there isn't any support under the front of your thighs.Fortunately there is a cure-shim the front of the seat bottom up.Luck,Charlie
