Ditto what keiffers said. The early TSBs did not call for replacement of the torque member and sliding pins. So someone getting the early TSB done would seem a more likely candidate for recurrence of the problem.
In reading the TSBs (I have), it seems to me the early TSB only addressed symptoms, not the underlying cause. That TSB called for replacing the torque member bolts, probably not because they are bad, but because EVERY brake service that calls for removing the caliper specifies replacing the torque member bolts. As I read it, the reason thus for removing the caliper was because the TSB called for machining the discs using an on-vehicle lathe, in which case you have to remove the calipers for clearance, and to avoid metal shavings. The original TSB also called for replacing the pads, but with the SAME pads. This is why I say the original TSB addressed only the symptoms.
The revised TSB additionally calls for replacement of the torque member, sliding pins, and revised brake pads, presumably to address the underlying problem causing the warpage, but who knows? Only time will tell...my $0.02
2004 Titan LE 4x4 King Cab - Radiant Silver
Navigation/Off-Road/Big-Tow
2002 Yamaha FZ1 - Silver
2001 KTM 520EXC
