b-lsd light staying on - Nissan Titan Forum
post #1 of 3 (permalink) Old 07-29-2013, 03:02 PM Thread Starter
iTrader Score: 1 reviews
Anyone experience this? It came on while driving on the highway. The truck seems fine no weird noises or anything.
2004 Nissan Titan - SOLD!!!
TitanNgtiGuy is offline
Advertisement
post #2 of 3 (permalink) Old 07-29-2013, 04:39 PM
NBhunter80's Avatar
iTrader Score: 0 reviews
Re: b-lsd light staying on
Check your brake fluid level. I have had that light come on before due to low brake fluid. Topped up the fluid and everything was good. If low brake fluid level is not the issue, then start looking at your wheel speed and ABS sensors. A sensor could be damaged or dirty. If you have an axle seal leak in the rear end, that can foul the speed sensors and cause similar issues.
2005 Titan LE King Cab 4x4 Offroad Big Tow FFV.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, LT315/70r17 Kelly Safari TSR tires on OEM OR 7-spoke 17" rims, Rough Country 3" lift, 1" rear block, Bilsteins 5100s front and rear, 2011 Pro4x rear end, Axle vent mod, 2 degree timing advance, NGK Iridium spark plugs, Stock Airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top D34 battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
2012 Nissan Rogue SV AWD - Wife's ride
NBhunter80 is offline
post #3 of 3 (permalink) Old 07-29-2013, 05:05 PM Thread Starter
well the fluid is a little low but not real low. I will get some fluid and fill it up a little.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
SLIP light staying on bbenjamin21 Electrical & Wiring 2 12-04-2011 11:30 AM
Service engine light and slip light staying on!!! 2004titan Titan Problems & Dealer Service 1 07-13-2011 05:24 AM
SLIP light staying on? bet1277 Titan Problems & Dealer Service 3 07-10-2011 08:17 PM
SLIP Light Staying On? Hot_Titan Titan Problems & Dealer Service 11 07-20-2007 12:44 PM
SLIP light staying on imjustdamngood Titan General Discussion 6 10-19-2006 12:40 PM
You may post new threads
You may post replies
