Old 10-19-2004, 07:16 PM   #1 (permalink)
Drivers seat moves by itself
I was showing the truck today to the guys at the oil change place today when the front seat moved by itself. I don"t have memory option. I had the front door open and the rear open also. King Cab. Then on its own the seat began to recline forward. This was the first time I have seen this. I used the power seat button to recline it back. About a minute later it did it again. I thought maby this was an option to assist in getting in and out of the rear seat. I can"t make it happen again. Didn"t see anything in the manual about it. Can someone help me out here? Thanks
sndmn2 is offline   Reply With Quote
Old 10-19-2004, 07:33 PM   #2 (permalink)
pyromedic's Avatar
I remember back when the 04' first came out there was some talk about this. I thought they had this problem taken care of. Do a search through the archives and see what you come up with. You should take i to the dealer. If this thing happens while you are driving it could cause you to have an accident.
LE CC Titan / Silver 05'
Big Tow/Navi
Born on 10-09-04
number 1301
pyromedic is offline   Reply With Quote
Old 10-19-2004, 07:48 PM   #3 (permalink)
Unhappy
mine has done the same thing 6 or 7 times. only when the truck is not running. it has also done it when i was in the seat. i think it's possessed! lol
i have se popular with bucket seats and no memory.
2007 GALAXY BLACK 4X4 BIG TOW SE POPULAR
C/C POWER PEDALS XM DELPHI
OEM ADD ONS--BUG SHIELD--RUNNING BOARDS
SPARE TIRE LOCK--ARE LSII W/REMOTE LOCK
CUSTOM PAINT- PINSTRIPING & GRAPHICS.
russ101 is offline   Reply With Quote
Old 10-19-2004, 07:52 PM   #4 (permalink)
sndmn2, you evidently have the power seats...(duh!)...
I am not familiar with your truck, so what packages do you have? I have an LE, and I do have the memory seats. With the LE I have memory seats (from the package) but I also have an seat entry/exit function (from which I am not sure if that's part of having an LE, but I suspect not).
My Ent/Ext function moves the driver's seat back a couple inches when I turn the key off and open the door. (& close the door &using the fob, lock the door). Additonally, if am outside and I use the fob to unlock the door, then open it & insert the key, it returns to exactly the same position that it was in before this whole description. (disclaimer.... providing that my legs or rear-end don't touch a switch during getting in or out of the truck)
by the way, for those who have memory seat, I do have 1 memory set, but I have not linked the memory to the fob since my last disconnected battery. So, when I do move the seat by the switches, then the E/E function returns it to the last "Switched" position, not to the memory position.
SndMn2, unfortunately, it sounds like you might have an issue that is not really related to the E/E function though.
--JAOHN
[SIZE=1]EDIT: changed "legs or rear-end touch a power switch" to "legs or rear-end don't touch a switch" [/SIZE]
JAOHN is offline   Reply With Quote
Old 10-20-2004, 06:10 AM   #5 (permalink)
TriKKy's Avatar
The exit/entry only moves it back, his was forward.
The only thing I can think of is that sometimes if I am getting in or out or working on something around the driver's side I will lean on the switches and move it.
Other than that I have no idea.
1.
Old 10-20-2004, 07:57 AM   #6 (permalink)
tnbowhunter's Avatar
It's getting close to Halloween, I bet it's possessed.
2001 Polaris Sportsman 500.
Old 10-20-2004, 10:33 AM   #7 (permalink)
TallTexan's Avatar
Same problem here. The seat recline seems to move somehow but always forward. I find myself having to recline the seat back almost everytime I get in the truck. I have not been able to find what happens. I have sat on the switch a few times and have the seat recline. I do not have memory seats.
Old 10-20-2004, 12:17 PM   #8 (permalink)
azxr's Avatar
Mine seems to change on me without any input on occasion. However, I have found myself leaning over the seats and hitting the switch by accident.
_________________________________________
2004 Titan SE KC 4X4 - Pearl White
Born on 7/14/2004
Purchased on 8/28/04
SE Off Road Package
SE Utility Bed Package
Rockford Fosgate with Power Captain
azxr is offline   Reply With Quote
Old 10-20-2004, 12:21 PM   #9 (permalink)
Hey TallTexan,
I thought I was crazy because mine did the same thing for the first month I had it. Everytime I got in the truck, I had to recline the seat back.
I really think what happens is when I was getting in the truck, I'd hit the switch or the bottom seat cushion would. It never seems to do it while driving and now when I get in I sort of hop my but over that edge of the seat. Seems not as big of problem.
If someone finds a better reason, such as a bad switch or something, let me know.
MikeD is offline   Reply With Quote
Old 10-20-2004, 12:45 PM   #10 (permalink)
I heard a rumor last winter (right after I ordered) that part of the Canton factory was built on an ancient burial ground.
Some of us are likely in serious trouble.
Certain service departments are going to need some very specialized training.
Jim in NH
Copper LE CC (mine)
Born 2/25/04. 4 WD, Big Tow, Nissan Hood Protector, Weatherflectors, Truxedo LoProfile, PIAA 1500 Backup Lights, CompuStar Remote Start, OEM Sirius & Sigma antenna, K&N drop-in.
Galaxy SE KC (son's)
Born 5/10/04. 4 WD, Big Tow, Popular Package w/captains, Utility Bed, Weatherflectors, Truxedo LoProfile, PIAA 1500 Backup Lights, CompuStar Remote Start, K&N drop-in.
jburson250 is offline   Reply With Quote
Old 10-20-2004, 02:19 PM   #11 (permalink)
itrice's Avatar
Noticed the same thing. If I am sitting on edge of seat reclines foward. I figured seat must be hitting switch. Have not had any problems when seated in middle of seat.
SE King Cab 4x4 - Born on 1/04
Big Tow - Off Road / No E-Locker
Rockford Fosgate with Captains Seats
Utility Bed - Lower Tray - Tool Box
Weatherflectors
Lund Interceptor Bug Shield
Westin Bull Bar
Westin Driving Lights
AFE Stage II CAI
Bilstein 5100 adjustable front shocks - set at 1" lift
Icon Rear Shocks
SkyFi 2 XM radio
Cell phone install kit w/ SmoothTalker 3 watt booster
- almost always have a good signal now.
itrice is offline   Reply With Quote
Old 10-20-2004, 02:19 PM   #12 (permalink)
I thought I was just imagining this myself. I have an SE with the Popular package. The build date is 08/04. I'm 6 4 so I tend to recline back a bit to give me some more leg room but there are times when I get in and the seat seemed to have move forward again. It moves so much that I can definitely see the difference looking in the rear view mirror.
Tim
2004 Radiant Silver Titan SE 4x2
Tim Sloper is offline   Reply With Quote
Old 10-20-2004, 03:05 PM   #13 (permalink)
roadtripper's Avatar
Whew!!! I thought I was losing my mind or something ....... driver's seat often seemed to be slightly different in the morning from how it was when parked the night before. Had to recline the seat back just a touch. It is reassuring to know that my truck is just possessed and I'm not losing my mind.
yes you are ... no I'm not ... yes you are ... no I'm not.
roadtripper is offline   Reply With Quote
Old 10-20-2004, 04:36 PM   #14 (permalink)
This has happened to me multiple times but everytime it happens I am getting in truck so I kind of wrote it off to somehow I am hitting switch with back side of my leg as I slide in. It has never done anything while driving, just when I get in truck.
I have been thinking about putting a switch somewhere near seat buttons to kill power.99% of time I am one who is using truck so it seemed like a good idea. If wife uses it, just toggle the power back on and make adjustments and toggle back off.
Havent done it yet though.
MikeZ is offline   Reply With Quote
