Old 10-24-2004, 03:36 PM   #1 (permalink)
Front Differential Fluid Change
I want to change the front differential fluid to Synthetic. I need to know what size and type of tool is required to remove the fill plug on my front differential..
L.A.FIREMAN is offline   Reply With Quote
Old 10-24-2004, 04:06 PM   #2 (permalink)
Any 3/8" socket wrench. (no socket, just the wrench).
MikeZ is offline   Reply With Quote
Old 10-24-2004, 04:16 PM   #3 (permalink)
tnbowhunter's Avatar
That's what I thought also Mike, I knew the rear diff uses a 3/8 drive but I'm at work so I couldn't be sure about the front.
A 3/8 breaker bar might give a little more leverage.
"It is not through knowledge, but through experience of the world that we are brought into relation with it."
__Albert Schweitzer
2001 Polaris Sportsman 500.
Old 10-24-2004, 04:39 PM   #4 (permalink)
Given what MikeZ says, prob. similar to http://www.titantalk.com/forums/show...0&postcount=20
Service Manual states front/rear routine maint. much the same, except has this statement re rear:
If using the vehicle for towing, the rear final drive oil must be replaced every 3000 miles or every 3 months, whichever comes first.
1. Remove the filler plug.
2. Remove the drain plug and the final drive oil.
3. Apply sealant to the drain plug threads.
__Use High Performance Thread Sealant or equivalent.
__Nissan North America Part No. (USA): 999MP-AM002P
__Aftermarket Cross-reference Part No.: Permatex 56521
4. Install the drain plug and tighten to specification.
5. Refill the rear/front final drive with new specified oil.
6. Check the oil level.
7. Install the filler plug and tighten to specifiction.
Final drive fill/drain plug torque:
27 N·m
2.8 kg-m
20 ft-lb
Front final drive fluid volume, per service manual:
1.6 liter
3 3/8 US pint
But, would fill to bottom of fill opening.
• XE Crew 4X2 | Deepwater | | Graphite|Titanium | with XE Preferred Package
• Column shift | Front bench seat
• Born 07/23/04
• Service Date 09/23/04 | 76 miles
• Wheel lug nuts torqued to 85 ft-lb | JetTech
• Front side window tint - dealer installed
• Grille inserts - small hole chrome | Bumper insert - small hole satin black
_ with license plate cutout - TitanTalk Dunder23 - Dan -
• Truxedo Lo Profile tonneau - eBay - premierecompaniesllc - T. Lowe
• Lund Interceptor Hood Deflector - paintable clear backside
_
- Deepwater body color - PickupSpecialties.com
billaku is offline   Reply With Quote
Old 04-14-2008, 06:34 AM   #5 (permalink)
Juday's Avatar
Re: Front Differential Fluid Change
Alright, extreme noob question (forgive me for asking this). I'm going to change my front differential fluid here shortly and I'm wondering where exactly the front differential plug is located in reference to the engine oil plug. Is it more towards the front of the truck (ahead of the engine oil plug), or is it more towards the middle of the truck (behind the engine oil plug)?
I know you're thinking this is crazy for me to be asking this, but this is going to be my first time changing front differential oil. Hey, we all have to start somewhere right? I've changed every other fluid in vehicles, just never a front diff, so cut me some slack...
BTW, I'm replacing it with AMSOIL Severe Gear 75W-90 (only the best )
If you happen to have a picture of the location of the plug, that would greatly help out. Thanks fellas.
35x12.5x17 Cooper Discoverer STTs
AEM Brute Force CAI
TomTom One XL Navigation
2* Timing Advance
PRG Shackles (Still need to install these...)
PowerSlot Cryo Rotors w/ Hawk LTS pads from Frozen Rotors
Superchips Cortex
Old 04-14-2008, 09:58 AM   #6 (permalink)
Juday's Avatar
Bump back to the top. C'mon people, I know those of you who changed your own can tell me.
AEM Brute Force CAI
2* Timing Advance
Superchips Cortex
Old 04-14-2008, 10:23 AM   #7 (permalink)
chunko's Avatar
It's on the axle. The axle is the cylinder that the wheels are connected to, follow it from the wheels to the middle of the truck...you will see it get big in the middle...that is the differential. The plug is in the bottom. This plug will just have a square hole in it...not a standard hex hole, or bolt.
To remove, use your socket wrench without a socket.
2005 CC 4x4 SE
AKA
TreeHuggingHippieWhore
"What if we picked the wrong religion? Every week we're just making God madder and madder." - Homer Simpson
chunko is offline   Reply With Quote
Old 04-14-2008, 11:46 AM   #8 (permalink)
54warrior's Avatar
WTF is a socket wrench??? It's called a ratchet damn it!!!
2005 Nissan Titan CC SE 4x4
Old 04-14-2008, 11:52 AM   #9 (permalink)
chunko's Avatar
http://www.answers.com/ratchet&r=67
http://www.answers.com/socket+wrench&r=67
2005 CC 4x4 SE
AKA
Old 04-14-2008, 11:53 AM   #10 (permalink)
Juday's Avatar
Sweet, thanks adavis.
AEM Brute Force CAI
2* Timing Advance
Superchips Cortex
Old 04-14-2008, 12:07 PM   #11 (permalink)
Blackbeauty's Avatar
Don't worry Warrior... In Michigan, it's "pop", but to the rest of the world, it's "soda". It ain't nuttin but a thang.....
Old 04-14-2008, 12:21 PM   #12 (permalink)
54warrior's Avatar
Actually, it's 'pop' back in western PA where I come from too!!!
And while the technical name for it might be a socket wrench, I've never in my lifetime heard anyone say "Hey, would ya hand me that socket wrench", but I have heard "I need an extension for this 3/8" rachet", etc.
Sorry, guess it struck me as 'odd' being called a socket wrench.
Old 04-14-2008, 12:31 PM   #13 (permalink)
chunko's Avatar
We use pop here too...
2005 CC 4x4 SE
AKA
Old 04-14-2008, 12:35 PM   #14 (permalink)
OK. You guys are all just WEIRD!
Old 04-14-2008, 12:41 PM   #15 (permalink)
chunko's Avatar
never a truer word spoken.
2005 CC 4x4 SE
AKA
