The 4 lo light flashes on and off I read other posts about taking off battery cable off or a bad sensor on tranny which one worked for you that had the same problem
Dealer needs to replace switch. If part is in stock, it's a 1/2 hour fix - tops.
I had them perform an oil change and rear end dif. check at same time to save a trip.
