Old 10-28-2004, 07:55 AM   #1 (permalink)
leeroy300's Avatar
Exclamation xm tuner
I was wondering if someone could give a part# for the factory tuner. I live in Canada and none of the dealers are willing to help me except for one who would help me out if I got a stock number ...... Thanx
leeroy300 is offline   Reply With Quote
Old 10-28-2004, 09:17 AM   #2 (permalink)
Pugsly's Avatar
Nissan part# 999U9-NV003 - Satelite Radio
or oder it from jamie on the web and save over what the dealer will charge you.
[FONT=Comic Sans MS][SIZE=5]This Boy Just Ain't Right[/SIZE][/FONT]
All Mods removed, none worked for me, drives much better stock
Pugsly is offline   Reply With Quote
Old 10-28-2004, 10:12 AM   #3 (permalink)
who is jamie on the web? or where is jamie on the web?
Dunkan21 is offline   Reply With Quote
Old 10-28-2004, 10:32 AM   #4 (permalink)
Pugsly's Avatar
Jamie is the rep for the one of the site sponsors http://www.nissanparts247.com/en_US/
they sponsor this site, but pm titanparts1 (jamie) and he'll get you a quote for the parts you need.
Old 10-28-2004, 06:31 PM   #5 (permalink)
schneid's Avatar
All you need is the tuner, antenna, and splitter
In addition to Nissan724, Grubbs Infiniti sells the kit. You do not need the the factory antenna extension or mounting bracket. Bolt the tuner to the back of the knee plate under the steering wheel. Buy any of the new low profile antennas plus a splitter as the tuner has two inputs. XM Fan and My Radio Store have the antennas. Blizsafe, Terk, or whatever you want. I got a Blitzsafe with splitter for $55.
schneid is offline   Reply With Quote
Old 10-29-2004, 01:45 AM   #6 (permalink)
leeroy300's Avatar
Thanx for the Help
Old 10-29-2004, 06:50 AM   #7 (permalink)
This is really good information for those of you considering Nissan's XM receiver. I originally followed Nissan's instructions, which involved securing the XM receiver to the RF amp bracket. That involves unbolting the gas pedal & adjust assembly & the body control module. Then, when installing amps & speakers, I had to disconnect the RF amp, which involved doing that again. So now, after removing the RF amp, I have the XM receiver installed as suggested in the quoted post. The Nissan XM receiver has only three things you need to connect: the NBUS cable that goes to the head unit, the antenna (via splitter if you use a modern single wire antenna), and a little ground wire. Also, the XM receiver is pretty light in weight. It really shouldn't be that big of a deal to install (as it is a big deal if you do so according to Nissan's instructions).
Also, when installing the antenna, you might consider whether you are going to install amplifiers at some later time, and run your antenna wire accordingly. I initially had the XM antenna wire running down the driver's side. Then, I installed amplifiers, and ran the power cable down the driver's side, and had to move the XM antenna wire (roof mount thru third brake light) over to the passenger's side to keep it away from the power cable. The wire that comes with the little Terk roof mount is very long, so there is no problem with length--you can run the wire pretty much any way you want.
Old 10-29-2004, 07:43 AM   #8 (permalink)
Nuckle's Avatar
I am thinking of doing this also. Is there a way that we could see some pics? How well does the system work?
Nuck
Nuckle is offline   Reply With Quote
Old 10-29-2004, 04:12 PM   #9 (permalink)
Pugsly's Avatar
i'm going to go sirius but am still up in the air about weather to go OEM via underdash mount (love the clean look but not the lack of scroll or high price). went to circuit city and played with the sportster and loved it. ((downside is having a controller mounted somewhere and figuring out a clean way to mount it, but love the lower price and the way the controller functions)
decisions, decisions decisions!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 10-30-2004, 07:28 AM   #10 (permalink)
leeroy300's Avatar
I would like the clean look and not really to concerned about xm or siruis but man the price is the killer what we need is an electronics wizzard to make an adapter from n-bus to din ...... all he would need is both the stock tuner and a direct tuner from xm and take them both apart ( the wizzard gets the idea ) !!!!!!
Old 10-30-2004, 07:29 AM   #11 (permalink)
leeroy300's Avatar
P.S and not charge to much for the adaptor ie.... $10 .... sign me up for one
Old 10-30-2004, 07:50 AM   #12 (permalink)
that item WAS discontinued as they were waiting for a new design, etc. i got everything but my xm from jamie at titanparts247 he was def the best and the cheapest too
i would wait until the new design comes out if u find an old one please post where from as there are a lot of people looking for them for the 2004 models.
the 2005 has xm installed on some models.
400 price
mine was 400 for the kit and 200 labor so better off to get it from the factory
dcrobt is offline   Reply With Quote
Old 10-30-2004, 07:55 AM   #13 (permalink)
good luck
nice option xm tuner
Old 10-30-2004, 09:02 AM   #14 (permalink)
I was thinking about this also. The wiring diagram for the NBUS is in the service manual at AV-29. So my question is would this be a simple job like just splicing the NBUS cable to the signal cable/connector of a standard XM receiver, or does Nissan's XM receiver have a chip with some special firmware?
Old 10-30-2004, 09:55 AM   #15 (permalink)
schneid's Avatar
Re Photos of Sat Tuner Knee Plate Install
I have previously posted my install pix here.
