Old 12-07-2004, 01:03 PM   #61 (permalink)
Originally Posted by loufish
I thought the 18" wheel package, and the 17" wheel package were real close to the same diameter.
I looked at tire/wheel offerings for the Titan
and they don't even offer a 18" option.
According to KBB.com they have the standard
P245/75R17 and optional P285/70R17. No
18" wheel offered. The standard is apx. 2.25"
smaller in overall diameter than my P275/60R20.
The optional P285/70R17 is about 2.50" smaller
in diameter than my 20's.
Hemi4Me is offline   Reply With Quote
Old 12-07-2004, 01:13 PM   #62 (permalink)
Originally Posted by MO Titan
4X4 Quad Short
No wonder you can beat him. I don't think
the off road tire option for the Titan is
33". Not a P285/70R17 tire!!
Old 12-07-2004, 01:14 PM   #63 (permalink)
Banned
My titan came with 18'' wheels from the factory. go to nissanusa.com and look at the car. kelly blue book is the worst website on the planet... stick to nissanusa.com or edmunds.com if you want worthwhile information.
Also, regardless of what size wheel/tire combo you have, you need to be within +/- 3% of the overall rolling diameter... if you go beyond that your speedometer will be incorrect.
Eraz3r is offline   Reply With Quote
Old 12-07-2004, 01:18 PM   #64 (permalink)
MO Titan's Avatar
Per www.nissanusa.com
off road tires P28575R17(with off road package reguardless of trim level)
XE (no off road)tires P24575R17
SE and LE (no off road) P26570R18 also the diameter of these on tire rack is listed as 32.6"
By the way, dodge's 2 options for their 20in rims are both 33" in total wheel diameter. I guess that "but there are 20 rims tires on it" isn't much of an excuse any more!
Oddly enough, my daughter just made this same face!!!
My Truck: Born April 17, 2004, Purchased June 3, 2004
LE Canteen Crew, 4X4, BT, OR to which I added: SS Brake Lines, Advanced Folding K-Cover ,SS Lund deflector, Black Prism DunderDan grill (I hope it's coming soon), 4" Prerunner Greg Performance Lift, The first Zoomers SS exhaust ever shipped, Volant Gen III CAI, and Chick's Hulk engine cover, custom A-pillar with 1in guages (coming soon).
As Money Allows: Nismo Headers, Dynatech 2.25" Powercats (Damn Missouri and your air quality) Osirus, Trutrac, Stillen (sway bar, big brakes, diff cover), and PrerunnerTraction Bars.
MO Titan is offline   Reply With Quote
Old 12-07-2004, 01:20 PM   #65 (permalink)
GETSOMZ28's Avatar
All the tires for the Titan (both 17 and 18") measure close to 33".
285/70/17 = 32.7"
265/70/18 = 32.6"
Scott
Old 12-07-2004, 01:23 PM   #66 (permalink)
MO Titan's Avatar
Look it up!
http://www.tirerack.com/tires/Spec.j...87TR7RUGTTAOWL
Old 12-07-2004, 01:42 PM   #67 (permalink)
I concede!! I just looked at a Titan where I work
and it had 18's on it. They measured just under
32 inches. Can't see the off road tire option in 17"
being 33" as someone stated.
Old 12-07-2004, 01:49 PM   #68 (permalink)
MO Titan's Avatar
Click on my link and you will see!
Old 12-07-2004, 01:49 PM   #69 (permalink)
The BFG website shows 32.8" for the off road 17" tire.
Zardoz
Zardoz is offline   Reply With Quote
Old 12-07-2004, 01:53 PM   #70 (permalink)
Zardoz
OK Gotcha!! You guys win!!
Old 12-07-2004, 03:06 PM   #71 (permalink)
Banned
The 20" wheels kill the performance of the Hemi's? What's the height of the 20"s? Are they taller then my 18"s?
I'd bet not. They probably have a lower profile tire to make up the difference. The 20" wheel issue means squat. I tend to believe it's more about gearing than wheel size.
OnebadSE is offline   Reply With Quote
Old 12-07-2004, 09:40 PM   #72 (permalink)
RockyMtnTitan's Avatar
Originally Posted by Mike Up
Edmunds is wrong as were a lot of other websites. They were using a prototype curb weight. The curb weights can be found by subtracting the payload from the GVWR. Nissan's website for the 2004 Titan had the curb weights but that information is now corrupted on the 2005 Titan site.
All Titan's have a GVWR of 6499 lbs according to Nissan's site. I know mine does.
Have a good one.
Thanks for the info........I thought the 5341 curb wt from edmunds seemed a little high.
Steve
Performance Mods:
Airaid TB Spacer
TB Coolant Shut-Off
Active Tuning Grounding Kit
Int/Ext Mods:
SE Pwr Mirror Upgrade
Factory Step Rails
17" OR Wheels
SE Sunvisors Upgrade
20% Window Tint
Old 12-07-2004, 09:46 PM   #73 (permalink)
GETSOMZ28's Avatar
Actually, performancewise it means quite a bit. The 20s are much heavier than a 17 or 18" rim. Also, the weight is further out from the axle centerline and has much more rotational mass. This puts it at a serious disadvantage. Also, lower profile tires have much stiffer sidewalls, hence less flex and less grip from a stop.
Scott
