Old 11-05-2004, 07:54 PM   #1 (permalink)
hunka27's Avatar
can't remove door panel/window handle
I have the XE with the manual windows, i'm taking the door panels off to add my own power door locks and power windows kits i bought, I searched and found how to remove the screws but i can't get the window handle off, does anybody know how to do this? thanks
hunka27 is offline   Reply With Quote
Old 11-05-2004, 08:14 PM   #2 (permalink)
phillipyang's Avatar
Send a message via AIM to phillipyang
I don't know anybody who did this yet but you can probably find the answer to your question from the nissan manuel found online for download.
Nissan Titan LE 4x2 CC
Purchased: Feb 2004
Miles to date: 74,000 (Since Feb, 15 2004)
Mods: Banks Cat Back Exhaust System, K&N with arbox mod, Front Air Dam, Custom bed cover, AC/DC interior conversion, PSP/Ipod Dock
http://www.phillipyang.com
phillipyang is offline   Reply With Quote
Old 11-05-2004, 08:28 PM   #3 (permalink)
hunka27's Avatar
i'd prefer not to pay money, hoping it will be in there... thanks for the suggestion.
Old 11-05-2004, 08:37 PM   #4 (permalink)
adjmcloon's Avatar
On my Armada there is a panel cover on the handle, and behind that panel cover 2 screws (deep set- philips type). I just remove those along with 3 others (one behind panel's arm rest, and two more around the door handle) and then pull kinda hard. Pops right off.
adjmcloon is offline   Reply With Quote
Old 11-07-2004, 07:41 PM   #5 (permalink)
Just added power windows, power door lock kit, keyless entry with alarm to my xe. There is a little clip holding the handle on the shaft. With the handle pointing up, use a tool with a small hook to pull up on the clip. You must pull the handle out slightly to see the clip which is between the handle and the black circle plastic piece.
Chris M. is offline   Reply With Quote
Old 11-07-2004, 07:47 PM   #6 (permalink)
pyromedic's Avatar
On most other cars that I have delt with there is a C-clip on the inside of the window handle. You can use a Flat head screwdriver to get behind it and pop it off.
LE CC Titan / Silver 05'
Big Tow/Navi
Born on 10-09-04
number 1301
pyromedic is offline   Reply With Quote
Old 11-07-2004, 09:51 PM   #7 (permalink)
pciley's Avatar
nawww, I would use a hook tool like Chris suggested unless you have spare clips lying around. They tend to fly away with a screw driver.
It is easy to see if you PUSH in on the panel and pull out on the handle, you can get almost 1/2" gap to get a hook in there.
TAKE NOTE of the alignment of the handle BEFORE you take it off so you can put it back on at the same angle.
KC XE Smoke
Old 11-08-2004, 04:09 AM   #8 (permalink)
If your adding Power windows do you need to know where the handle was aligned b/c wouldn't you be taking it off and replacing it with a switch? I understand why alignment would be critical if you were not making the mod.
TuffTitan is offline   Reply With Quote
Old 11-08-2004, 11:15 PM   #9 (permalink)
pciley's Avatar
haha.... good point. yeah, if you are doing the whole job at once you won't need to worry about the handles pointing different directions, good call!
Questions: The kits come with plastic plugs for the hole where the handle is now. Does the plug match? Does it fight right? Do you need to grind down the spline shaft that comes out of the hole so the plug will fit plush?
KC XE Smoke
