Not trying to flame or start an argument, but where was it stated or mentioned that premium is suggested for max performance by Nissan? I may have missed it, but I could be wrong.
Again, not trying to be a jerk - just curious. What I found in the Owner's Manual is:
FUEL RECOMMENDATION
Use unleaded regular gasoline with an octane
rating of at least 87 AKI (Anti-Knock Index) number
(Research octane number 91).
The AKI is equal to the octane rating on the pumps, making Regular Unleaded the acceptable choice for the Titan.
Also note the following about using other grades of fuel:
Octane rating tips
Using unleaded gasoline with an octane
rating lower than recommended can cause
persistent, heavy spark knock. (Spark
knock is a metallic rapping noise.) If severe,
this can lead to engine damage. If you
detect a persistent heavy spark knock even
when using gasoline of the stated octane
rating, or if you hear steady spark knock
while holding a steady speed on level
roads, have a NISSAN dealer correct the
condition. Failure to correct the condition
is misuse of the vehicle, for which NISSAN
is not responsible.
Incorrect ignition timing may result in spark
knock, after-run and/or overheating, which may
cause excessive fuel consumption or engine
damage. If any of the above symptoms are encountered,
have your vehicle checked at a
NISSAN dealer.
I hope this helps. I do know that on other Nissan vehicles such as the 350Z, Premium was recommended in the same fashion that Regular is recommended for the Titan.
Just trying to help cut down on the misinformation. Others have spoken to using a higher grade of fuel than recommended, so I won't go through it again. I don't advocate using higer octanes than recommended, but that's my opinion and choice only.
Regards,
Z33Fan
Originally Posted by OnebadSE
I use regular but I use premium sometimes. The slight difference in performance probably isnt worth the extra cost but Im used to using premium on my other vehicles that require it. Itll run fine on regular but premium is suggested for max performance according to Nissan.
