Originally Posted by Titan Critter
apparently, it will have a bedliner and trac system from the factory. what a novel idea.....too bad it was someone else's!
It's not a bedliner in the new Tacoma. The inside bed walls are made of Fiber-reinforced Sheet-Molded Composite (SMC) instead of a metal. You don't need a bedliner in this since theoretically it wont rust or dent. Only time will tell how strong and durable this material will prove to be. If if does live up to Toyota's claims, however, it will be better than metal sprayed with a liner.
JD
