Old 11-09-2004, 04:18 PM   #1 (permalink)
2005 Power Rear Window
Well, just came from the local Nissan Dealer and found out some information on the Power Rear Window as it relates to the 2004 Titan. Both the Parts Dept. & Service Dept. said that the new window would fit in the 04's. So off to the service dept. for the cost of making the change. Rear Window was priced at just over $500, and the power regulator was priced at $220. Now for the down-fall: they were not able to find the wiring harness for the rear window. The Parts Manager mentioned that he believes that you would have to replace the whole cab harness. For when he looked it up all he was able to find was the 05 cab wiring harness as a whole unit. No where did it show the rear power window wiring harness as a seperate unit. He did say that you could take the vin number from an 2005 Titan and look for the wiring harness that way.
If anybody comes across any further info. please post. Wife is really hounding me that we should have waited the 6 months before buying. Not only would we might not have the brake problems, but she would have the few new features that are now on the 05 Titan.
Feimrte is offline   Reply With Quote
Old 11-09-2004, 04:21 PM   #2 (permalink)
smoketitan's Avatar
hey I am in the same boat my titan friend wifey is all onmy case about the rear window also
Old 11-09-2004, 04:46 PM   #3 (permalink)
TIsTAN's Avatar
i believe this can easily be handled by a competent stereo shop and installer. all you need is a switch, maybe even the factory one, and know-how to hook it altogether. price is not bad, i may consider this as a future mod.
TIsTAN is offline   Reply With Quote
Old 11-09-2004, 04:52 PM   #4 (permalink)
Banned
Send a message via ICQ to Titan_TX Send a message via AIM to Titan_TX Send a message via MSN to Titan_TX
You could always wire it separately with some good wire. It's most likely 2 postive wires and a ground. One goes up, one goes down, and of course the ground.
Titan_TX is offline   Reply With Quote
Old 11-09-2004, 05:02 PM   #5 (permalink)
mtbendo's Avatar
Where does the window retract into? Does the back panel of the interior need to be replaced as well?
04 Galaxy Black Crewcab LE/Big Tow/Off Road/Nav/DVD
Hood Protector/Gibson SS Extreme Duals/Leer XQ Shell/AEM Brute Force
KC Backup Lights/Stainless Steel Grille/Chrome Tailgate Trim/PRG Mini Lift
mtbendo is offline   Reply With Quote
Old 11-09-2004, 05:13 PM   #6 (permalink)
dooboy2112's Avatar
Does your wife know that if the window down and there is dirt or loose stuff in the bed. Its doing to be sucked into or truck.
Titan page
04 Smoke KC SE 4x4
Offroad package
Big Tow
Utility Bed
K&N Aircharger
dooboy2112 is offline   Reply With Quote
Old 11-09-2004, 06:03 PM   #7 (permalink)
How wide is the window "part" that retracts?
How wide is the part of the window that retracts?The currect sliding window slides maybe 14" of window.What does the window retract into-into the rear"bulkhead" of the truck?Anyone have a picture?Thanks,Charlie
Old 11-09-2004, 09:10 PM   #8 (permalink)
Is the 2005 Titan service manual ready for download? Maybe you could look at the wiring diagram for the rear window and see if additional wiring can be done without replacing the harness.
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
Old 11-09-2004, 11:16 PM   #9 (permalink)
pciley's Avatar
Will all the equipment (regulator, tracks, GLASS, motor, etc.) Fit into that skinny place in the '04's back panel?
No harness extension will exhist for an '05 to simply "Plug in" to an '04. The power rear window was apparantly not a feature they planned on offering when the Titan debuted.
You will have to buy a whole new harness for all the power accessories in the cab, AND you might even have to buy a body control module from an '05 to control the new switch on the dash for the rear window.
This project could get expensive.
The window won't be powered directly. The switch is of a lower voltage than the power window motor and it will use the BCM like a relay to send out the 12V to the motor for that rear window.
I really hate how all the cars are becoming completely computerized. It makes it VERY hard for us do-it-yourselfers to do any mods.
KC XE Smoke
Old 11-10-2004, 08:40 PM   #10 (permalink)
mtbendo's Avatar
Looking at some 05 pictures it looks like the back panel is different. The panel below the window looks like it was all plastic on the 05 as opposed to the material/carpeted panel in the 04s. The picture is a bit hard to make out for sure.
