The truck has coil packs which are connected directly to the spark plugs. If you look at the cylinder heads you will find them on the top of the valve cover (remember this is a double overhead cam engine, these types of setups typically have the plugs mounted on the top of the cylinder head instead of the side). To remove the plug you'll need to unbolt the coil pack.
[FONT=Comic Sans MS]undefined[/FONT][SIZE=5]undefined[/SIZE]undefinedMike L.
