Old 11-11-2004, 09:46 PM   #1 (permalink)
rawze's Avatar
low tire light
my low tire light came on today(i had to look in the manual to see what the light meant) and all four had 25#. i put them up to 40 but the light is still on . i guess i need to unhook the negative to reset it. has anyone else ran into this?
RICK : TITAN NO MORE
I like the sound when i push the pedal down!!
I GET BORED UNLESS IT'S FLOORED
TRADED FOR A LIMITED 4X4 1999 4RUNNER
SILVER KC SE 4x4
rf w/captains
chrome bed rails
air box mod w/kn drop in
jba exhaust
wade bug shield
side window ventvisors
billet lower grill
line x liner
factory step rails
AVS headlight accents
rawze is offline   Reply With Quote
Old 11-11-2004, 09:54 PM   #2 (permalink)
scr38's Avatar
Drive it for a while at highway speeds, the light should go off.
Old 11-11-2004, 10:10 PM   #3 (permalink)
my tire light went on and i checked and is at 34 psi. Is 34 too low ?
Any suggestions is appreciated.
UTTitan is offline   Reply With Quote
Old 11-12-2004, 05:55 AM   #4 (permalink)
Z33Fan's Avatar
Recommended is at least 35psi. Some people here are running around 38-42 for better highway mileage.
Z33Fan is offline   Reply With Quote
Old 11-12-2004, 06:14 AM   #5 (permalink)
IMADOGMAN's Avatar
28 Psi
Mine occasionally comes on at 34 psi too, but it only seems to happen on a cold day. Manual says that the sensors should turn on the warning at or below 28 psi. I have always just overfilled them (40-42psi) and gone for a drive. Sensors work above 20 mph...and it takes about a mile or two to turn off the light, then I let them back down to 35-36 psi (cold).
IMADOGMAN
2004 NISSAN TITAN KC SE
4x4 Offroad (E-locker)
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
Old 11-12-2004, 09:06 AM   #6 (permalink)
keiffers's Avatar
Send a message via MSN to keiffers Send a message via Yahoo to keiffers
Mine came on last week when it got down to around 40 - checked the tires and they were all 25psi - left it alone and within a few days the light went out. Figured it was just the cold that made them go down. It was at the dealer this past Monday and they should have checked the tire pressure and fixed if they were low. I haven't checked again to find out if they're back up to where they should be.
Keith
2004 Titan SE KC 4x2 - Smoke
"Chester"
SE Popular w/bench
SE Utility Bed Package
Drop-In K&N Air Filter
Delphi Roady 2 XM Radio
Sylvania SilverStars
Nissan wind/bug deflector
Nissan fog light kit
(good riddance Goodyear!!)
Born On Date - 03/19/04
Adopted On Date - 06/28/04
Maxwell Town North Nissan - Austin, TX
keiffers is offline   Reply With Quote
Old 11-12-2004, 09:50 AM   #7 (permalink)
tnbowhunter's Avatar
Basically what everyone else said, I got up this past Sat. morning to go hunting, as you know Sat. was probably one of the coldest days of the year so far. I had driven less than a mile down the road when the alarm and the light came on. I pulled over and checked the tires and they looked ok, on the way home the temp went up and about half way home [20 miles] the light went out. I checked the tires and they all had around 32 psi. I aired them all up to 36.
I think if you drive the truck enough and the tires are aired up ok the light will eventually go out by itself.
2001 Polaris Sportsman 500.
Old 11-12-2004, 10:43 AM   #8 (permalink)
Kmu
Seems like I will have a constant alert because I like to drive on 28 PSI always, no matter what condition, on or off road...
To me going above 36 PSI its just to rought on the ride...
I rather have less tire life by going on 28 PSI but having a smooth ride..
Kmu is offline   Reply With Quote
Old 11-12-2004, 10:49 AM   #9 (permalink)
GA-matt's Avatar
Earlier this week with the cooler temps, my light also came on. I checked the pressure and all were around 30 PSI on my reader. Stopped by the gas station and put them all to 38 PSI. Drove about 1/4 mile and the light went off.
2004 Nissan Titan Crew Cab SE - Smoke
  • Off-Road
  • Big Tow
  • Utility Bed
  • SE Popular
  • Captains Chairs
  • Side Air Bags
  • Rockford Fosgate System
  • Delphi Skyfi 2 XM Receiver
GA-matt is offline   Reply With Quote
Old 11-12-2004, 10:55 AM   #10 (permalink)
IMADOGMAN's Avatar
Tire Pressure
It's about more than tire life, it is also about safety. Everyone here should read this:
http://www.tirerack.com/tires/tirete...l/pressure.jsp
And this: From another tire company...
Correct tire pressure is very important. Driving on any tire that does not have the correct inflation pressure is dangerous. Proper inflation pressure for your tires may be found in the vehicle owner's manual or the vehicle's tire information placard.
Any underinflated tire builds up excessive heat that may result in sudden tire destruction.
Refer to the tire placard on the vehicle (check vehicle and/or vehicle owners manual for placard location) for the recommended operating pressures. These pressures must be maintained as a minimum. Do not exceed the maximum pressure indicated on the tire sidewall of passenger car tires.
IMADOGMAN
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
Old 11-12-2004, 11:50 AM   #11 (permalink)
Wake County Titan's Avatar
It just started to get cold here in NC and my tire light came on. The buzzer scared the crap out of me. It lasted for a long time and at first I had no idea WTF was going on. I stopped by the gas station and filled them up to 40 and the light went off in a few miles. It has been off since.
2004 Nissan Titan LE - KC, 4x4, Smoke, Big Tow
Mods:
Flowmaster 70 Dual In/Out Exhaust w/X-Pipe, 3.5" Straight Rolled Tips
ARE LSII Bed Cover
4x4 Off Road Decals
JVC KD-G830 Receiver w/USB port
Rockford Fosgate Punch Stage 3 10" sub & P3002 amp
Polk db6500 & db650 speakers & Lightning Audio Bolt 300.4 amp
Wake County Titan is offline   Reply With Quote
Old 11-12-2004, 03:22 PM   #12 (permalink)
GA-matt's Avatar
Yep, unless you're deaf you certainly won't miss it!
  • Off-Road
  • Big Tow
  • Utility Bed
  • SE Popular
  • Captains Chairs
  • Side Air Bags
Old 11-13-2004, 12:40 PM   #13 (permalink)
Kmu
After reading this, I will set my tires to 34 PSI early in the morning, at the coldest point of the day, with the car parked in the garage for the whole night....
THX for the advise and link...
Old 11-16-2004, 02:55 PM   #14 (permalink)
You Should Run Your Tire Pressures Around 34-36 Psi, Keep In Mind That When The Tire Gets Warm With Driving, The Pressures Will Increase A Couple Pounds
salvanilla is offline   Reply With Quote
Old 11-16-2004, 04:08 PM   #15 (permalink)
I read somewhere, either in the owners manual or on the tires that they will take a max of 44 lbs. I keep mine at 42 to try to get the best gas mileage. I tried driving with 36 lbs of pressure and really didn't notice any difference in the ride quality, so I think I'll keep mine on the high end of the suggested pressure.
Stan
skromfols is offline   Reply With Quote
