suspension questions!
So here is my dilema. I have the street beat 2/4 lowering kit, but as I saw the pics of another titantalk member, once installed, the rear is about 3/4 inch lower. He said it would level out once the front springs break in, but how much? A full 3/4 inch? Also, I want to add jettech's helper springs after lowering it too, which as I think was also mentioned, also lowers the rear about 3/4 on 4x2 (correct me if I'm wrong). So with the kit and the helper springs, the rear would be 1.5 inches lower right off the bat? And at most I would think that the front springs would lower another 1/2 inch once broken in, if at all...Assuming that, my rear would still be 1 inch lower...So here is the question...I found some 3 inch lowering springs. This would cover that inch I have sagging in the rear...Or would it...I know this all sounds complicated, but if anyone understands it and could shed some light on this, I would greatly appreciate it....Thanks
