Old 11-15-2004, 08:43 AM   #1 (permalink)
Kmu
Urgent, Going to the dealer to pick up Titan...
Hi there, Im about to go to the dealer to pick up my Titan, its still a 2004 model, CC SE Off road 4x4 in white color...
Is there anything I need to look for or ask the dealer about? the Nissan manager is a friend of mine, what problems about the Titan should I warn him so later on warranty can cover it, and I can tell the manager, "See I told you so"
Anything extra?
THX in advance...
Kmu is offline   Reply With Quote
Old 11-15-2004, 08:47 AM   #2 (permalink)
phlydude's Avatar
Do a search on dealer checklist
Someone had a good post with 10-15 bullets on what to look for on the 2004s
phlydude is offline   Reply With Quote
Old 11-15-2004, 10:09 PM   #3 (permalink)
BRAKES!...BRAKES!...BRAKES!...BRAKES!...BRAKES!...
And don't forget to ask about the brakes. They have redesigned pads out. If you don't change them, your rotors WILL warp very soon.
Also... seatbelt recall.
giuseppe is offline   Reply With Quote
Old 11-16-2004, 09:17 AM   #4 (permalink)
Kmu
THX for the advise...
What are the rotors? any pictures?
THX again...
Old 11-16-2004, 10:03 AM   #5 (permalink)
phlydude's Avatar
THX again...
You're kidding right?
If you aren't, rotors are the shiny surface under the rim that the brake pads grab on to to stop the car. When they are no longer flat, they become warped and have to be turned on a lathe to scrape off the excess material to make them flat again.
Old 11-16-2004, 12:08 PM   #6 (permalink)
Nvr*lost's Avatar
I would ask for the build date,in the event you develop problems similar to the earlier built Titans.
Dayton, Ohio
Nvr*lost is offline   Reply With Quote
