Originally Posted by Mr. Fisherman
I have searched and viewed the threads and links I could find but still have not seen a tall shell for the Titan.
I would like something I can fabricate a carpet kit for so I could overnight in it if need be but still have room to store stuff securely.
Any links, pics or prices?
Thanks in advance...
Go to an ARE dealer and ask for info on DCE model. It is aluminum framed
in both directions and has a smooth aluminum finish. You can spec out
what you want including windows, doors or tailgate type, or even the
thickness of the aluminum skin. This is my second DCE canopy and they
are very well built. Now the bad part. Depending on what you get it can
get expensive if you let the options get out of control. You can also get
any type of roof racks you want including bracing running in both directions.
When you tie the roof racks to the canopy framing underneath you get
something very strong and rigid. I put two solar panels on top and bang
everything around death valley with no problems. These units are very
light considering the strength they have. Picture show my canopy and
you can get any height you want including a rounded front to cut the
air a little better if you choose a over the cab height configuration.
Another option is to go to a canopy dealer and many can order and have
built whatever you want but these tend to have the corrogated aluminum
on the sides and not look as good as the smooth side aluminum on the ARE
but they tend to be much cheaper but not as well built.
Zardoz
