If you hear gurgling there is air in the system. You'll have to burp it to get it out, just run the truck with the radiator cap off(makes sure its not hot when you remove the cap). It helps to point the truck up an incline. With the cap off run it with the heat on full blast, add coolent as nessasary and when the bubbles stop it should be done. With my supra everytime i get the gurgling heater core its always been a sign of a blown head gasket, I doubt thats your issue though. If burping doesn't help have the dealer replace the radiator cap.
04 Titan CC,BT,OR,4X4, 5333lbs, 15.42@88.79mph stock
Zoomers catback, 2* timing advance
