Old 11-20-2004, 10:59 AM   #1 (permalink)
Exclamation Power Steering Pump Leaks
Just as an FYI, check your power steering fluid level on your 2004. Not saying that this is a problem, but it could be. I drive a 2004 KC SE 4X4 and my power steering line was leaking pretty good. I was down to the Minimum hot level for fluid. The line that was leaking is the one that is just below the battery grounding point. It looks like it is about 3/4 to 1 inch and was leaking from the crimp just below the elbow. Hope no one else has the problem but check it and let the rest of us know.
TN Titan N MN is offline   Reply With Quote
Old 11-20-2004, 06:46 PM   #2 (permalink)
trowelsworth's Avatar
thanks for the heads up! i had problems with the tranny cooler crimps leaking. caught it early and replaced crimps with clamps.
trowelsworth is offline   Reply With Quote
