Old 11-20-2004, 11:35 PM   #1 (permalink)
Tourque spec
Seems as there is a lot of interest in differential fluids. Can someone post a tourque spec on the filler and drain nut ? I always feel more comfortable knowing my nuts are in spec.
sndmn2 is offline   Reply With Quote
Old 11-21-2004, 07:34 AM   #2 (permalink)
25 Ft Lb for the filler and 20 for the drain plug.........that sure seems loose after it took an impact wrench to remove mine.....
PS I believe something around here has been said about using a "high temp thread sealer" (not loctite) on the threads also....
2004 Deep Water 4x2 SE CC
Born 04/2004
Lund Interceptor Deflector
Line-X Spray in Liner
Retrax Retractable Bed Cover
More Goodies To Come
JBWilkins is offline   Reply With Quote
Old 11-21-2004, 07:52 AM   #3 (permalink)
loufish's Avatar
They are pipe threads, and I put teflon tape on the drain plug. Snug them up.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 11-21-2004, 08:27 AM   #4 (permalink)
Originally Posted by JBWilkins
... PS I believe something around here has been said about using a "high temp thread sealer" (not loctite) on the threads also....
From (04) Service Manual:
High Performance Thread Sealant
(Thread sealant only, no locking ability.)
Nissan North America Part No. (USA): 999MP-AM000P
Permatex 51813 and 51817
Permatex
51813 50 ml tube
51817 6 ml tube
Anaerobic Gasket Maker
Flexible non-corrosive material for use on rigid machined flanges with less than .015" gap. Used for aluminum to steel mounting surfaces. Cures without exposure to air.
http://www.permatex.com/auto/autouh....&item_no=51817
Suggested Applications:
Water pumps, thermostat housings, transmission pans, transmission case covers, transaxle casings, o-ring replacement
billaku is offline   Reply With Quote
Old 11-21-2004, 09:36 AM   #5 (permalink)
Thanks, just what I was looking for. Did you get your service manual at the dealer? Is there a cd version available ?
Old 11-21-2004, 09:47 AM   #6 (permalink)
RememberThisTitan's Avatar
make sure the thread sealent is high temp too. you can get it a pep boys or any other auto shop.
RememberThisTitan is offline   Reply With Quote
Old 11-21-2004, 09:56 AM   #7 (permalink)
I have some pipe sealant with Teflon in my toolbox that I already had for use on water pipes. I read the fine print instructions on the back and saw that it is rated for high temp (500+ degrees) high pressure (10,000 psi) and for oil and fuel. You might look to see if what you already have will do. This works great for me. I got a big jar at Ace Hardware.
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
Old 11-21-2004, 10:05 AM   #8 (permalink)
Originally Posted by sndmn2
... Did you get your service manual at the dealer? Is there a cd version available ?
Did a search: service manual download
Came back:
Is there a Manual out?
or
http://www.titantalk.com/forums/show...45&postcount=5
http://www.nissan-techinfo.com/nissa...M4E%2D1A60U1CD
2004 (CD) Nissan Titan Service Manual CD
$210.00 (USD)
http://www.nissan-techinfo.com/nissa...=SM4E%2D1A60U1
2004 Nissan Titan Service Manual (3338 pages)
$295.00 (USD)
http://www.nissan-techinfo.com/nissa...line1&mscssid=
One day Subscription (Adobe Acrobat pdf files)
$19.99 (USD)
Took me quite sometime to download all even with good fast DSL connection.
Looks like I ended up with 54 files - I arranged in 22 folders - was somewhat awkward, clumsy for me to keep track of in downloading or sometimes to now locate what I want to, but much less than $200, $300.
Old 11-21-2004, 02:44 PM   #9 (permalink)
pciley's Avatar
Just download (or if you already have it, place..) the files in the same directory. You will only need to look for "fwd.pdf" if you have the downloaded version from Nissan. That single file indexes you to every other point in all the other files. You shouldn't have to search for anything as long as you used the file names that came up as default when you were downloading. IF you renamed the files, however, the "fwd.pdf" index won't know where to look.
Good links above! The first two show you how to find the service manual for only $20 !!! but like billaku said, it does take some time (less than an hour) to download all the files.
KC XE Smoke
Old 11-21-2004, 07:06 PM   #10 (permalink)
as pciley said.......pay teh $20 and download it.....that's all I did.......
Born 04/2004
Old 11-22-2004, 10:26 PM   #11 (permalink)
Thanks for the links guys. I"m on dial up so I"ll have to have a buddy download for me. Thanks again.
Old 11-23-2004, 05:49 AM   #12 (permalink)
My mistake! Thought I'd rename so know more what each file about.
So, 'trick' is to do as above - thanks for info pciley!
